Hoe verplaats ik mijn script correct naar het nieuwe JS-tabblad in mijn component?
[Admin Notice] Theme ‘_Base’ contains code which needs updating. (id:discourse.script-tag-discourse-plugin) (learn more)
For one on my forum, I got rid of this message simply by moving my JS script to the new JS customization tab.
On my other forum, it doesn’t work that easily.
It’s an old override that shows the composer’s tag field only in categories that accept tags:
This script was heavily based on a similar (and old, 2019 or older) modification posted on meta, but I can’t find the original post anymore.
Anyway, there are two questions in one:
  1. How to properly move this in the JS tab? Is it possible, or should I create a theme component?
  2. Is there a more elegant way to hide/show the composer’s tag selector only in certain categories? I use tags for only 1 category on my forum (an ads category with #search and #offer tags)
I guess you could use CSS to show/hide the tag field based on the category class on the body, but whether that’s more elegant is up for debate :slight_smile:
It doesn’t solve it for staff [1], but if you set the tags as restricted to that category, they won’t be usable (by non-staff) on other categories. From a category /edit/tags:
Tags and tag groups specified above will only be available in this category and other categories that also specify them. They won’t be available for use in other categories.
  1. unless we Make category tag rules / restrictions apply to moderators too ↩︎
I had a look at how it works, since it has been a long time.
  • Tag inputs appear on the composer when creating a new topic regardless of the selected category (even if the category has no available tags for others than admins), which is I want to prevent
  • CSS only won’t work, because the composer can be open on any page, and there’s no parent CSS targetting the wanted category that would help hiding the composer’s tag input, which I believe is why I used javascript for.
So, unless I’m missing something I still need a script to achieve my goal.
The original #feature topic about this was here:
I guess not enough traction to have this feature worked on, and pr-welcome was not desired here according to sam.
So, stuck with a custom JS solution (which I need to fix then :smiling_face_with_tear: )
It should be possible to just copy/paste it. Stuff in the JS tab is run in exactly the same way as <script type='text/discourse-plugin>. If it’s not working, can you share the code?
With some crazy modern CSS, it’s possible:
.d-editor-container:has(.category-input .select-kit-header[data-name="Support"]) .tags-input {
    display: none !important;
^^ this hides the tag input for the “Support” category on Meta.
You can swap the [data-name="Support"] for :not(data-name="Support") to reverse the logic.
Heilige mol! Het lijkt erop dat mijn CSS-vaardigheden uit 2012 niet meer volstaan. Wat nogal vreemd is, want ik zweer dat 2012 letterlijk gisteren was!
Ik heb gekozen voor
.d-editor-container:not(:has(.category-input .select-kit-header[data-name=\"Trading Post\"])) .tags-input {
    display: none;
Dus het wordt verborgen in elke categorie behalve Trading Post.
Bedankt allemaal!
