Is there a way I can send email notifications faster?
In a discussion titled ‘Is there a way I can send email notifications faster?’, Richie reports that sending 22,000 emails from a scheduled post in the #Announcements category takes over an hour, which is too slow for time-sensitive messages. Monitoring Sidekiq shows emails queue up in ‘Scheduled’ before moving to ‘Enqueued’ for sending. supermathie explains two bottlenecks: delay in queuing (adjustable via email_time_window_mins) and processing speed (controlled by DISCOURSE_SIDEKIQ_WORKERS). Increasing workers from 5 to 8 (or higher, depending on server capacity) can speed up delivery 2x–4x. Richie confirms adding DISCOURSE_SIDEKIQ_WORKERS: 7 to app.yml is valid and rebuilds successfully. Despite the change, performance improvement is limited — supermathie suggests checking server load during processing; Richie notes CPU peaks at 44% but suspects Discourse may self-limit. supermathie clarifies each worker processes one job at a time — so 7 workers handle 7 emails simultaneously. To process 22,000 emails faster, more workers (e.g., 1000+) would be needed, but that’s impractical without massive server resources. tobiaseigen notes this is an ongoing server scaling issue. In short: increasing Sidekiq workers helps, but server capacity and job-per-worker limits constrain how much faster emails can be sent.
We have an #Announcements category in which all our members are automatically subscribed to watch the first post.
This allows us to schedule the publishing of posts in to that category on set times/dates.
In turn, the announcement is then emailed to around 25k members.
The problem we face is that the emails take over an hour to get sent, not ideal for time-critical announcements.
If I watch Sidekiq I can see the “Scheduled” counter racking up all the individual emails one by one, once it gets to around 20,000 it then moves them over to the “Enqueued” tab, and then they eventually start sending out.
Am I able to speed this process up at all? :thinking:
For time critical emails it’d be nice to send them out around 100x faster than they currently go :blush:
This discussion may help you, as it explains how to set DISCOURSE_MAX_DIGESTS_ENQUEUED_PER_30_MINS_PER_SITE, which defines the global limit for digests.
I timed it this evening.
I scheduled a post to publish in to the #Announcements category at 18:30.
At 18:40 there were 15,000 emails in the Scheduled queue.
At 18:45, so 15 minutes after the post, there were 22,000 emails in the Scheduled queue.
At 18:48 those emails then gradually started moving over to the Enqueued queue:
At 18:51 they were still moving over:
At 19:03 the emails were on their way out:
By 19:10 there were just 10,000 emails remaining:
At 19:27 there were just 569 emails remaining:
And at 19:29 all the emails had gone out:
So there we have it, one full hour to send 22,000 email notifications.
Can anyone help me identify the bottleneck here?
I’d very much like to be able to send these emails out faster than their current 22000-per-hour rate.
Shooting from the hip,
Is it possible it’s an infrastructure load issue?
Perhaps?
I genuinely don’t know :person_shrugging:
The CPU spiked to around 44% on the server:
And I use AWS SES for the SMTP.
There’s two things going on here:
  • delay while email jobs are enqueued
  • processing time for sending the actual email
For the first, I’m not 100% confident on this but I think lowering email_time_window_mins means the notifications get queued sooner.
Once the email jobs are scheduled, your sidekiq workers are working through them one at a time. Bumping up the sidekiq workers (set DISCOURSE_SIDEKIQ_WORKERS up from 5 to 10, 15, or 20 depending on server capacity) means more jobs get processed at the same time, so the queue gets emptied 2x/3x/4x faster.
I don’t know how the backend works in the finest detail, but the email_time_window_mins is just a delay setting before the first email goes out. During this time, any user that is set to receive the email may “forfeit” the email if they happen to be active within the window of period (official terminology: email skipped; skip reasoning: User was seen recently).
The default delay is 10 minutes, meaning the post must be live for 10 minutes, and only then will the emails be sent.
Richie’s issue is the time difference between the first email and the last email… a delay of one hour. This is probably due to the sheer amount of emails that need to be sent, though I cannot say for certain either.
Changing the setting above would only expedite the sending of the first email, but not address the completion duration of the entire batch of 22,000 emails.
What would be the recommended setting, obviously dependent on infrastructure capability?
Could a high setting result in server issues in terms of load or other?
“As many as the server can handle”.
It’s 100% dependent on the OP’s server capacity - too many and it’ll slow things down, too few and it’ll take longer to process.
Given the CPU graph hitting 40% (is that of a single CPU or total capacity?) I’d probably start with bumping it either 2× (conservative) or 3× (aggressive) and see what happens, depending on risk tolerance for slowdowns.
Great insight, thank you :slight_smile:
Does that DISCOURSE_SIDEKIQ_WORKERS have to be a multiple of 5? Could I set it to 7 for example?
I don’t have that parameter setting in my app.yml so I’ll assume it’s on a default of 5 somewhere.
Can I just create that setting under the existing unicorn workers setting, then rebuild?
Eg:
expose:
  - “443:443”
env:
    UNICORN_WORKERS: 8
Is it as simple as that? :thinking:
Is anyone able to confirm this is the correct change to make to my app.yml when the DISCOURSE_SIDEKIQ_WORKERS parameter does not currently exist?
I believe yes, given a brief inquiry to the AI bot.
Thanks @TempAccount
Interestingly, DISCOURSE_SIDEKIQ_WORKERS only appears eleven times across the whole of meta:
https://meta.discourse.org/search?q=%22DISCOURSE_SIDEKIQ_WORKERS%22%20order%3Alatest_topic
…and one of those is in this topic :flushed_face:
Yes, this is correct.
Any (most?) setting can be overridden in this manner. The default value comes from discourse_defaults.conf.
Thanks @supermathie
My app.yml now reads:
env:
  LANG: en_US.UTF-8
  UNICORN_WORKERS: 8
  ## Added this line on 04/10/25
  ## REF: https://meta.discourse.org/t/is-there-a-way-i-can-send-email-notifications-faster/383103/12
I’ll rebuild later in the week and time it sending emails :smiley:
Just so I know my change has taken effect, am I right in thinking this Threads value should increase from 5 to 7?
Yes, confirmed:
@Richie were you able to resolve your issue?
Thanks for following up.
No, alas not.
I’ve increased the threads from 5 to 8 but the emails are still taking the best part of an hour to send from start to finish.
I’d expect maybe a 40% increase in total throughput.
When jobs are queued, do you see 7/7 utilisation?
Also, look at the server load when it’s processing them, and if you can bump it up further I’d recommend doing so.
Ohhhhhh wait a minute. Is Discourse limiting itself somehow?
Have I missed a setting that’s restricting its CPU usage?? :scream:
It’s not limiting itself per se but each sidekiq worker will process one job at a time, so if you have 22000 emails waiting to go out seven of them will be processed at once.
On the ridiculous side of things, the server probably won’t be able to keep up if you set the number to 1000 parallel workers. So it’s about finding a number that suits all of your needs:
  • process as many jobs as possible at the same time to get through the 22000 emails faster
  • but don’t take up ALL of the server resources which would leave none left for users of the site
