Photos are display in half in chrome, PWA, Edge and Incognito Mode
We need your support to fix the issue of having the pictures displayed in half#
This appears in edge, chrome and even incognito mode
We are using the open source discourse
Does the same happen if you look at images here on Meta? This is an example topic with some images.
Does safe mode change anything?
@Moin
yes here the images are displayed accurately
but our system it’s half
Does safe mode help? Perhaps a component or plugin could be affecting lightbox behaviour.
@NateDhaliwal
the same issue after applying the safe mode
I can reproduce the issue here on Meta after changing my interface language to Arabic
So I think it’s a Bug in the updated lightbox feature
I need your support to fix the problem with our Arabic interface where the images are displayed in half
I have previously added a post in support and they found that it’s in the Arabic interface
need your support to fix it
Check here it’s shows that even discourse meta when changed to arabic shows the same way
@Eman_Ahmed I’ve moved your post to the same bug topic. One bug topic is enough, there is no need for duplicates.
Thank you for reporting. This change should fix the issues you were experiencing:
please note we still face the inconvienance
kindly let us know when it will be fixed
I can no longer reproduce the issue here on Meta
Is your site public, so I can try it there?
This topic was automatically closed after 3 days. New replies are no longer allowed.
thank you we are facing the same inconvenience and it’s not resolved
image1850×805 177 KB
it’s half displayed where it should be dragged by the mouse to get the full view
kindly resolve it
Does this also still happen here on Meta?
since I’m using meta in english it doesn’t occur
it happens when we use discourse in arabic language
unfortunately, it’s a private site guide us to fix it
Why don’t you change your interface language here to test?
changed to Arabic and I didn’t face any problem
the issue is in our open source site
how to resolve it?
If it doesn’t happen here, it might have something to do with a customization in your forum. Have you tried safe mode again?
yes and nothing has changed for our users using discourse in Arabic
Kindly support us in this
