FIX: Disable load_more_replies button until more replies are loaded
In PR #35136, a debounce logic is added to the reply button. However, a similar issue occurs in the “load_more_replies” button as well.
This commit fix the issue by adding disable logic to the load_more_replies button, so that the button is also disabled when loading, and this issue is solved.
A PR to solve this is here:
https://github.com/discourse/discourse/pull/36816
3 לייקים
Thank you for your contribution!
2 לייקים
This topic was automatically closed after 20 hours. New replies are no longer allowed.
