The following interpolation key is invalid: site_name
סיכום מבוסס בינה מלאכותית
Users reported an issue where the interpolation key %{site_name} was invalid in the welcome banner header text for logged-in users, though it worked for anonymous visitors. Moin noted that site_name is only available for anonymous users since logged-in users have a display name, and hipp0 confirmed the limitation while seeking to use %{site_name} for logged-in users too. awesomerobot acknowledged the oversight and submitted a fix, which was later merged. manuel explained the technical blocker: backend validation rejects interpolation keys not present in the default locale strings. Moin suggested a theme component workaround or a core PR to add site_name for logged-in users. Finally, manuel confirmed the fix was deployed, making %{site_name} available across all welcome banner header fields for both anonymous and logged-in users.
Alright thanks for the info, for now I am using CSS to put the site name. Was just having a problem underlining it in the welcome text.
That makes sense. They didn’t log in, so we don’t know who they are. There is no name for them in the database.
It’s like when someone you don’t know rings your doorbell; you won’t be able to greet them by name until they introduce themselves.
Yes, but I would like to use that %site_name for logged in users as well ![]()
Thanks for reporting it! Looks like I over-promised which variables were available…I’ve got an update coming that will correct this.
So we still can’t add %{site_name} if user is logged in?
The siteSetting service might work to get the value of the title site setting
I looked into this, the blocker here is not accessing the value of title. It’s that the backend validates translations by extracting valid interpolation keys from the default locale strings.
So when %{site_name} is not in the default string, it is rejected as an “invalid interpolation key”.
I don’t know what @NateDhaliwal’s idea is. I only wanted to point out an alternative to an additional request to /about.json.
I think a custom component that copies the welcome banner but provides the site_name key for all texts would be the way to go.
Or a PR that adds site_name as available key to the texts for logged in users in core
get headerText() {
if (!this.currentUser) {
return i18n("welcome_banner.header.anonymous_members", {
site_name: this.siteSettings.title,
const isNewUser = !this.currentUser.previous_visit_at;
const key = isNewUser
? "welcome_banner.header.new_members"
: "welcome_banner.header.logged_in_members";
return i18n(key, {
preferred_display_name: sanitize(
prioritizeNameFallback(this.currentUser.name, this.currentUser.username)
+ site_name: this.siteSettings.title,
@hipp0 thanks again for raising this! We pushed an update that makes the site_name variable available on all three header fields:
