Moetwemoji: Lightweight Animated Emojis (AVIF) - Bring your forum to life
סיכום מבוסס בינה מלאכותית
The discussion centers on Moetwemoji, a Discourse plugin introducing lightweight animated emojis using AVIF format. The author, tom_eric, presented two versions: an Override (replacing defaults) and a Pack (supplementing them). However, the initial post contained broken links redirecting to Google searches instead of GitHub, which drew criticism from Moin and Jagster for being non-standard and requiring extra effort to find documentation.
A significant portion of the thread focused on installation and troubleshooting. tom_eric provided a detailed manual guide for the Override version, explaining that while it works without a rebuild, changes are not persistent across container restarts. Users like gilles and agent_kith reported that despite following instructions, the animated emojis did not appear in the chat interface, often due to caching issues or confusion over the specific rake tasks required. Moin clarified that the manual rake task is essential to swap the default emoji paths.
Additionally, Canapin raised concerns about the plugin’s naming convention and incomplete attribution to Google’s Noto Emoji project. tom_eric acknowledged these issues, promising to update the README, clarify asset sources, and fix the naming confusion. Finally, merefield suggested simplifying the documentation by removing the manual container entry instructions, recommending the standard app.yml hook method for persistence and ease of use.
PixPin_2026-01-04_22-04-17
Hi everyone! :waving_hand:
I created a new plugin to bring more energy and dynamic expressions to Discourse communities. Moetwemoji introduces a set of animated emojis that make interactions more lively and fun.
:rocket: Key Features
  • Super Lightweight: All emojis are encoded in AVIF format.
  • High Performance: The average file size is only around 10KB, ensuring your forum loads fast while looking great.
  • Flexible Deployment: I offer two different versions depending on your needs (Override or Supplement).
:package: Choose Your Version
I have prepared two separate repositories depending on how you want to integrate these emojis into your forum.
Option 1: The Override Version (Total Replacement)
If you want to completely replace the default static Twemoji set with these animated ones, use this version. It overrides the system defaults, making the animation the standard experience.
Option 2: The Pack Version (Supplement)
If you prefer to keep the standard emojis and simply add these as an extra “Pack” in the emoji picker, use this version. It adds a new tab to your emoji selector without touching the defaults.
19 לייקים
Thanks for sharing :+1:
I wanted to test it but it doesn’t work despite adding the repository in the app.yaml file
Is there a setting to configure?
Thanks
OK please try Manual Install
Manual Installation Guide (Override Version)
This guide explains how to manually install and apply the
discourse-moetwemoji-twemoji-fakepng-override plugin inside a running Discourse container, and clarifies why a full rebuild is not strictly required for the override version.
1. Enter the Discourse Container
On your server, go to the Discourse Docker directory (usually /var/discourse) and enter the running container:
cd /var/discourse
./launcher enter app
You should now be inside the container shell.
2. Clone the Override Plugin Manually
Navigate to the plugins directory and clone the repository:
cd /var/www/discourse/plugins
git clone https://github.com/constansino/discourse-moetwemoji-twemoji-fakepng-override.git
Verify that the directory exists:
ls discourse-moetwemoji-twemoji-fakepng-override
3. Apply the Emoji Override
Go back to the Discourse root directory:
su - discourse
Check the current status (optional but recommended):
RAILS_ENV=production bundle exec rake moetwemoji_twemoji:status
Apply the override:
RAILS_ENV=production bundle exec rake moetwemoji_twemoji:apply
If the command finishes without errors, the Twemoji PNG files have been replaced by Moetwemoji.
4. Important Notes About Rebuilds (Persistence)
:red_exclamation_mark: No rebuild is required to make the override work
This override version works by directly replacing files in the running container.
Therefore:
  • :white_check_mark: You do NOT need to run ./launcher rebuild app
  • :white_check_mark: Changes take effect immediately after running the rake task
:warning: But the change is NOT persistent
Because this is done inside the container filesystem:
  • Any future ./launcher rebuild app
  • Or container recreation / upgrade
will wipe the changes, and the emoji override will be lost.
:backhand_index_pointing_right: If you need persistence across rebuilds, you must install the plugin via app.yml hooks and rebuild properly.
5. Clear CDN and Browser Cache (Very Important)
After applying the override, emoji may still appear unchanged due to caching.
5.1 Clear CDN Cache (e.g. Cloudflare)
If you are using a CDN such as Cloudflare:
  • Purge cache for:
    • /images/emoji/*
    • or perform a full cache purge if necessary
Otherwise, the old Twemoji PNG files may still be served.
5.2 Clear Browser Cache
On the client side:
  • Hard refresh the page (Ctrl + F5 / Cmd + Shift + R)
  • Or clear browser cache
  • Or test in an incognito/private window
Until both CDN and browser caches are cleared, emoji changes may not be visible.
6. Summary
  • This override plugin can be installed and applied without rebuilding
  • Manual installation is useful for:
    • Testing
    • Temporary usage
    • Debugging
  • The downside is lack of persistence
  • Always clear CDN cache + browser cache after applying emoji overrides
Did you run the task as described in the README?
This README provides two installation methods:
  1. The first method requires a rebuild.
  2. The second method is to manually enter the container and download it from GitHub.
There’s no difference between the two methods; the former is simply more persistent. If the download fails when rebuilding using the first method, consider trying the second method, which involves directly installing within the container. This is because it essentially downloads and replaces existing emoji images.
I noticed that the Readme explains 2 installation methods, but it also mentions:
cd /var/discourse
su - discourse
which is not mentioned in the first post here on Meta. Just like the information about caching. That’s why I thought someone might miss that.
By the way, both of your links in the first post contain a Google search. Is there a reason why you did not link to GitHub directly?
לייק 1
Why is it called “moetwemoji”, and the emoji folder called “twemoji” when the animated emojis are official animated Google Noto emojis?
This is however mentioned in this file, where the attribution is incomplete. The file is said to be work in progress but I’d expect an attribution to be complete before distributing your theme component :face_with_tongue:
5 לייקים
Sorry, my post may not have been comprehensive enough. I will revise it later. Thank you for your correction.
2 לייקים
Thanks for pointing this out — you’re absolutely right.
The naming is historical and comes from Discourse’s default emoji
structure, but the actual animated assets are from Google Noto Emoji,
not Twemoji. I agree this is confusing and needs to be clarified.
I’m currently:
  • Updating the attribution to fully comply with the Noto Emoji license
  • Clarifying the asset source in the README
  • Reviewing naming / folder structure to reduce confusion
Thanks for the review and for catching this.
2 לייקים
I will wait because despite the manipulations it does not work, however my Discourse is on a standalone server on my Ubuntu server. I don’t know if I have an extra manipulation to do concerning the cache?
just try
https://“yourdomain”/images/emoji/twemoji/hugs.png?v=15
and
https://“yourdomain”/images/emoji/twemoji/hugs.png?v=15&cache=0
Both urls give very stable and motionless emoji. So, based of that I don’t see any reasons install this. A device question?
I think those links are for testing the plugin after installing it. As long as you don’t use the plugin, you are going to see the emoji which the plugin would replace.
I actually installed it, and I don’t see anything. Perhaps I should use another emojies on Discourse settings or something else, I don’t know [1]
  1. plus I personally think moving elements are echoes from 90’s :squinting_face_with_tongue: So I’m not so motivated to start dig this deeper. ↩︎
Sorry, because you said you don’t see a reason to install it, I assumed you did not.
Did you run the rake task that is explained in the readme of the plugin’s repo? I think that’s what puts the animated emoji where you tried to access them with the links
לייק 1
My bad. I’m on phone and I was/am lazy to write then.
No, I didn’t do.
Edit.
I never red the readme, because OP offers only (useless) link to google search. Now I did extra steps to original repo to find info that should or could be in OP.
לייק 1
I can see the animated emojis with “https://“your_domain”/images/emoji/twemoji/hugs.png?v=15” but when I try to select an emoji in the chat, for example, it doesn’t work :thinking:
To reduce complexity I recommend you remove everything related to not rebuilding and entering the container to clone. This is unnecessary and not the standard way to manage plugins.
Almost all admins will be rebuilding periodically and persistence is the most important aspect, so the app.yml method is best.
You can also link to standard instructions and just detail steps that are unique.
3 לייקים
So I am using the persistent method:
  1. Add the git clone command in my app.yml file
  2. Entered the container and ran the 2 rake commands
  3. Verified the link “https://“your_domain”/images/emoji/twemoji/hugs.png?v=15” works on my site
  4. Cleared cache, set my cloudflare protection to dev, and so on.
  5. But when I look at the emojis, they’re still pointing to the original path, e.g.: images/emoji/unicode/upside_down_face.png?v=15
What other step(s) am I missing? How do I swap the default emoji to use this one?
