Hi everyone! ![]()
I created a new plugin to bring more energy and dynamic expressions to Discourse communities. Moetwemoji introduces a set of animated emojis that make interactions more lively and fun.
Key Features
Super Lightweight: All emojis are encoded in AVIF format.
High Performance: The average file size is only around 10KB, ensuring your forum loads fast while looking great.
Flexible Deployment: I offer two different versions depending on your needs (Override or Supplement).
Choose Your Version
I have prepared two separate repositories depending on how you want to integrate these emojis into your forum.
Option 1: The Override Version (Total Replacement)
If you want to completely replace the default static Twemoji set with these animated ones, use this version. It overrides the system defaults, making the animation the standard experience.
- Repository: discourse-moetwemoji-twemoji-fakepng-override
Option 2: The Pack Version (Supplement)
If you prefer to keep the standard emojis and simply add these as an extra âPackâ in the emoji picker, use this version. It adds a new tab to your emoji selector without touching the defaults.
- Repository: discourse-moetwemoji-pack
