๐Ÿ–ผ๏ธ Topic Gallery
:information_source: Summary Add a gallery view for each topic
:eyeglasses: Preview Click to see a gallery example
:hammer_and_wrench: Repository Link https://github.com/Canapin/discourse-topic-gallery
:open_book: Install Guide How to install plugins in Discourse
Description
Topic Gallery displays all images from a discussion on a dedicated page.
Use cases
Ideal for image-focused communities and/or categories in which users post many pictures.
It allows for a full picture experience without the regular topic interface and other contents getting in the way.
Mobile view:
You can try it here. This is primarily a test instance, so the availability is not guaranteed.
Features
Main features
  • Infinite swiping! [1]
  • User and date filters
  • Starts gallery from a given post
  • Group-specific access
  • Category-based exclusions
  • Link to the source post below the currently open image, so youโ€™re never lost:
    Gallery Topic source post link
  • Shows grouped pictures (belonging to the same post) on mouse over:
    Topic Gallery grouped pictures
Navigation from a topic to a gallery
Several buttons are available to navigate from a Topic to a Gallery:
  • Below the timeline:
  • At the end of a topic:
    Topic Gallery topic button
  • On each post (can be disabled in the settings):
    Topic Gallery post button
    :information_source: If you open the gallery from a post, the gallery is filtered and only shows images starting from this post. You can cancel this filter with a single click:
Gallery URLs
The gallery URL syntax is the same as a regular topic, but /t/ is replaced with /gallery/:
https://canapin.discourse.diy/t/share-your-pictures/10
:backhand_index_pointing_down:
https://canapin.discourse.diy/gallery/share-your-pictures/10
Thereโ€™s also a public JSON endpoint:
https://canapin.discourse.diy/gallery/share-your-pictures/10.json
Security & queries
  • Feature access is restricted to allowed groups and in allowed categories.
  • Galleries are restricted to users with access to their source topic.
Uploads queries exclude:
  • Non-user-uploaded images
  • Non-post references (custom emojis, avatars, etc.)
  • Uploads from posts that the current user has no access to, meaning:
    • Whispers (if the current user canโ€™t see whispers)
    • Hidden posts
    • Deleted posts
    • Ignored usersโ€™ posts
Gallery Behavior
  • Hotlinked images are not shown.
  • Small images are not shown (minimum resolution can be changed in settings).
  • Duplicate images are shown once.
  • Images inside quotes are shown.
  • Images in spoilers or any other block that alters their visibility, are shown.
Settings
Name Type Default Description
topic_gallery_enabled boolean true Enable the topic gallery plugin.
topic_gallery_allowed_groups group_list admins Groups that are allowed to access the topic gallery.
topic_gallery_minimum_image_size integer (0โ€“1000) 64 Minimum width and height (in pixels) for images to appear in the gallery. Images smaller than this in either dimension are excluded.
topic_gallery_excluded_categories category_list "" Categories where the topic gallery is disabled. Topics in these categories will not show gallery buttons or the gallery page.
topic_gallery_post_menu_button boolean true Show a gallery button inside each post.
:information_source: By default, the plugin is enabled for admins only. Visit settings to enable other groups.
  1. Reaching the end of the first batch of images automatically loads and appends the next batch. โ†ฉ๏ธŽ
17 ืœื™ื™ืงื™ื
I finally released this plugin :slight_smile:
You can see a preview here: Gallery - Share your pictures! - Canapin
6 ืœื™ื™ืงื™ื
This is such a cool idea and implementation.
Will try this later but is there a way to add image description that would show on the image popup below image?
ืœื™ื™ืง 1
I think you can use alt text:
![Some alt text here](upload://...)
You can also click on the above image to see the alt text.
3 ืœื™ื™ืงื™ื
Ah, thereโ€™s an oversight from me. This pluginโ€™s photoswipe configuration seems to show the original filename instead of the custom title. Iโ€™ll fix this :slight_smile:
4 ืœื™ื™ืงื™ื
@Canapin Why not use the built-in Discourse lightbox()?
Apparently, while I can use the built-in lightbox (thatโ€™s I was doing in the first versions of this plugin), I canโ€™t configure and tweak it for my needs. Notably, I couldnโ€™t have it interact with my methods for the infinite loading/swiping, so I had to ship my own.
ืœื™ื™ืง 1
I canโ€™t fix this, unfortunately. Image titles are written in the postsโ€™ content and arenโ€™t stored in any table.
For performance reason, my queries donโ€™t return the postsโ€™ content, so I canโ€™t parse it to retrieve the titles.
I guess Iโ€™ll leave the filenames then. Even tho this information is rarely valuableโ€ฆ :thinking:
Non-modified filenames most of the time just reveal where the image comes from and nothing more.
For example in my test instance:
  • image.png โ†’ โ€œimageโ€ filenames are images pasted directly in the composer
  • Gemini_Generated_Image_8h4wt58h4wt58h4w.jpg โ†’ Guess
  • ComfyUI-ExtraMD-Large_315126945425344_00000.jpg โ†’ Local AI image generator
  • the-tattooer-is-totally-right-v0-s2f8spm3l-D5908.jpg โ†’ Probably saved from a website
  • cropped-android-chrome-512x512-1-32x32.png โ†’ Smartphone screenshot
Etc.
Should I consider it as a sensitive information? Image names are used by default for titles when we upload them on Discourse. If we edit the titles, the original information is unavailable for users. Yet, this plugin discloses it.
Edit: Yeah, I should probably not display the original filename. :thinking:
Re-edit: Fixed. :slight_smile:
ืœื™ื™ืง 1
Gallery icon at the bottom of a topic on mobile is not designed well. (Does not follow other buttons shape/size). Looks fine on desktop. Thank you.
ืœื™ื™ืง 1
Before
After
Fixed, thanks for the report :slight_smile:
ืœื™ื™ืง 1
Thank you! Would it also be possible to have a setting do disable the automatic โ€œfrom post #123โ€ when a user clicks on the gallery button mid-topic please? So basically the full gallery available no matter what specific gallery button you click. :slight_smile:
ืœื™ื™ืง 1
You can disable the post buttons in the pluginโ€™s setting. The remaining gallery buttons (timeline, and end of topic) open the gallery from the start.
ืœื™ื™ืง 1
UX questions for connoisseurs.
More often than not, on desktop and mobile, I want to open the gallery from the last unread post:
For example, I open a topic, and it shows this:
My first instinct, especially on mobile, is to click the gallery icon next to the topic progression element. But this icon opens the gallery from the start.
If I want to open the gallery from the current post, I need to scroll down until I reach the bottom of the post, where the โ€œopen gallery from current postโ€ button is:
Iโ€™m not sure how to solve this. Should I change which buttons open the gallery from the beginning or from the current post? Should I move the button somewhere else?
Any idea welcome :grinning_cat:
ืœื™ื™ืง 1
In the context of a forum for a school (one category per class), this plugin is quite interesting !
We can post pictures, add comments and have a nice overview.
Particularly useful would be this pull request: Add sitewide and category gallery scopes - Pull Request #23 - Canapin/discourse-topic-gallery - GitHub
Indeed the use case would be opening topics per events and posting pictures related to an event in a dedicated topic.
And with the sitewide and category gallery scopes people can have a nice overview of all pictures without having to go into each topic !
ืœื™ื™ืง 1
I hear the request :slight_smile:
Iโ€™m not against adding a setting for this.
But Iโ€™m not a programmer (I know the basics, though), and while I took the time and made the effort needed to fully review and understand the code AI provided for my plugin to ensure it was safe and reliable, Iโ€™m neither confident or motivated enough to review the current PR and ensure itโ€™s as safe as reliable as the existing code, and that it doesnโ€™t clutter the existing codebase.
Iโ€™d be very happy if an experienced programmer could review this change. I cannot allocate my own resources for this, but having a sponsored review (+ fixes of refactor if needed) would allow me to implement the feature.
If someone can have a broad estimate of how much time (or money, but thatโ€™s the same thing right?) such a non-AI work would take, perhaps it can be posted on Marketplace? :slight_smile:
ืœื™ื™ืง 1
A fix was pushed regarding groups permissions as per Granular group-based permissions for anonymous and logged in users.
So please update the plugin on your forum :slight_smile:
:warning: If you previously had the group permission set as everyone, you need to change it for anonymous_users and logged_in_users for unregisterd users and registered members be able to see the galleries.
The demo link in the first post was broken because of this, and I repaired it.
2 ืœื™ื™ืงื™ื
Just want to thank for sharing this functionality and add my vote to the possibility of showing a general gallery.
It would be great if the same could be filtered by categories or tags :slight_smile:
