404 Facebook Fetch
#1
upon checking on facebook the site is not recognize and it shows 404 when fetch to facebook here is screenshot
(Michael Downey) #2
Is this related to Discourse? If so, what are you trying to do?
(Jens Maier) #3
Yep, looks more like a transient connectivity problem between Facebook and your server. iframely.com/debug finds all relevant Open Graph data without problems.
(Khoa Nguyen) #4
DId you try the Fetch new scrape infomation button?
#5
yes I fetch it but still dont work @thangngoc89
@downey yes this is discourse related since when shared to social media it must show the metadata
#6
is there additional code needed to add in order to discourse add the images on the OG:image ?
(Khoa Nguyen) #7
That’s a long story
There is a 500 error when crawler hit your Discourse. Didn’t you edit anything or place any proxy in front of your Discourse
#8
Finally Fixed it :smile:
added this line of code with the .conf file
listen 80;
listen [::]:80;
and as I fetch it worked :slight_smile:
(Khoa Nguyen) #9
@rnovino are you using a docker install?
#10
yes I did used docker
