Category hashtag floating cards and subcategory hashtag display improvements 🎈
סיכום מבוסס בינה מלאכותית
The discussion focuses on improvements to category hashtag displays and the introduction of floating preview cards. martin announced that subcategory hashtags will now display only the child category (removing the > separator) and trigger a floating card containing the category description, icon, parent links, and recent topics. This feature is gated behind an experimental setting. The change aims to address feedback that full category paths (e.g., Parent > Child) are too verbose inline, a concern highlighted by satonotdead and awesomerobot. However, this creates challenges for sites with duplicate subcategory slugs across different parents, which putty noted required the parent context previously.
A significant portion of the thread debates the UX of the floating card. bartv and chapoi argued that the card adds an unnecessary extra click, breaking the expected behavior where links navigate directly. bartv expressed strong skepticism, viewing it as a “meaningless extra step,” a sentiment echoed by Jagster, who noted their non-technical users prefer direct links. Conversely, stephtara found the card beneficial on mobile for providing context and recent activity without leaving the current page, helping users who might otherwise get lost in complex taxonomies.
To address the navigation friction, martin suggested double-clicking to go directly to the category or adding a explicit “Go to topics” link in the card. merefield and chapoi proposed using hover tooltips for desktop users to preserve direct clicking behavior. martin confirmed a separate PR had fixed the inline shortening of hashtags. Ultimately, martin shared a new PR implementing hover-only cards for desktop, allowing clicks to navigate directly to the category, aiming to satisfy both those who want quick access and those who prefer standard link behavior.
We are making some changes and improvements to how subcategory hashtags display per Can we make inline links to subcategories more concise?, and at the same time are adding the same floating card functionality that you already see for user mentions e.g. if you click on @martin .
This card will show the category title, icon/emoji, description, as well as links to any parent categories. Users with permission can see the “Edit description” button, as well as the “New Topic” button, which is also category context dependent (e.g. Events categories will have a “New Event” button).
Also shown in the card is a list of the 3 latest topics in the category. Users without permission to see a category will simply follow the hashtag link, and see no card.
Subcategory hashtags will have the > separator removed, and only show the child category. See below for a before & after:
This behaviour is all gated behind the Enable category hashtag cards upcoming change:
It’s enabled here if you want to see for yourself before you try it on your own site. Click any category hashtag in a post to take a look, e.g. News and Events or Community Building
14 לייקים
Will we be able to permanently disable these cards? As a user, if I click on that link I just want to go to the category page, not some intermediary step.
Also as UX feedback: how would you go from the card to the category topic list? It’s not clear from the screenshots.
2 לייקים
I think you can click on the category name in the card—just like you can click on a username on the usercard to open the profile.
2 לייקים
The feature is enabled here, so you can try it out before you tinker on your own forum.
It’s still a work in progress, so we’ll take feedback here into consideration and make tweaks to it before we promote the Upcoming Change to beta/stable (it’s currently still in the experimental phase).
I agree the click target could be more obvious. Perhaps the whole card should be a click target aside from any more specific elements.
לייק 1
Having a few examples in the first post would be nice for people who won’t read replies and just want to see the feature in action :slight_smile:
לייק 1
Seems great to test it, thanks. How a subcategory like Announcements - Discourse Meta actually looks?
My bad, they need to be called manually (#) like this: News and Events > Announcements
I wonder if displaying the top category only on the card makes more sense now that the information of the categories is on the modal? I mean not inline anymore when using #.
לייק 1
I think that was the idea
3 לייקים
I’ll definitely implement this when the separator bug is fixed! I have dozens of categories with the same slug, so including the parent category in the hastag is mandatory. I’m hoping with this change I can update the category display names to include the parent name, though. Doing so with the old method was clunky, like 1Secure > 1Secure Ideas—but this new change could flatten it to just 1Secure Ideas.
CleanShot 2026-09-17 at 09.35.56
2 לייקים
I don’t think we will keep this as an option…we have so many settings :smiling_face_with_tear: What I think I will do at least is if you double click, it will take you to the category. Also you can click the category name in the card popup.
Also you can just do this if you want a direct link to a category https://meta.discourse.org/c/news-and-events/announcements/67 it will turn into Announcements - Discourse Meta .
Good point – I think we could add a “Go to topics” link here:
3 לייקים
I’m OK letting this simmer a bit in experimental while we tinker with the design though, @martin and @awesomerobot.
4 לייקים
For sure, it doesn’t need to move forward for a while (we will be busy with meetup shortly anyway :slight_smile: )
I’m sorry but I’m skeptical about this feature. For users, being able to glance at their data in a card makes sense. But for categories or tags I fail to see the added value. If anything, this makes things worse by adding a meaningless extra step.
That’s not a realistic workaround, as it would require a user to first find that category link somewhere else. This is also making the UX worse.
Sorry, not a fan :slight_smile:
2 לייקים
Quite many of my users are using PWA. Then getting any links is a bit harder task. Otherhand, they aren’t linking categories and I bet that is true in majority of non-technical forums, where userbase is from social media, not from gaming, tech, IT etc.
I’m not a fan either. It seems like nowadays system is moving toward all-cards desing instead of getting what is looking for. Perhaps I’m so old school that I’m expecting a link beeing a easy way to get the target.
But if I as an admin can choose not to use it, then it doesn’t matter (and in my circles users, those few who has an opinion, don’t like it and if theirs taste changes, and I will move to cards right away. After all my forum is for discussion by users, not for me).
3 לייקים
First, thanks so much for this! I started shuffling categories on my Discourse install again and realised the parent category > child category display of hashtags in text was really niggling at me again (we have lots of categories and we mention our categories and subcategories a lot to guide our users around). So I checked back to see if things had moved forward since our first discussions about this, and it has! So happy.
I personally wouldn’t have needed the cards (just the more concise subcategory link) but on second thought I quite liked the idea. At least for my population of users, being able to see a preview of a category or hashtag really makes sense. I did, however, imagine it as a hover", and when I realised it was on clic my reaction was “oh wait, what, another step? double-clicking on hyperlinks?!”
This was exactly my reaction: we’re just adding an extra click to open a link… meh.
But then I tried it on my phone and changed my mind: the card gives me a really good overview of what the category is (if I had any doubts… remembering that people using a taxonomy generally find it less intuitive than those who came up with it) and gives me a hint of what the latest posts are, which actually gives me a chance to not head over to that tag or category if it wasn’t what I wanted.
My users are not that comfortable in digital spaces and get lost. This is definitely, as I see it, going to help them not lose track of where they are, not end up somewhere they didn’t really want to be because they clicked on a few words that looked promising to them but weren’t actually the right call.
So, right now, quite enthusiastic and have enabled the preview for my community. We’ll see how it works in practice.
But… I can imagine other community scenarios where this would not work. I agree that we don’t want to make everything a setting (we’re already drowning in them, I complained about that enough). But… I feel this does “break” the expected pattern of how things work online: click on a link, get taken to the destination. Type a hashtag, that means people can click on it to see everything related to that hashtag. So I’m not really sure what the way around this is.
Perhaps the solution is on another level, in how Discourse as a tool deals with two apparently conflicting intentions:
  1. be very flexible and customizable
  2. offer a great experience “out of the box”
The team might already be on this (or this might be an idea that doesn’t work, or maybe I’m stating the obvious, or late to the game, or beside the point or displaying my ignorance of how things work) but it seems to me that the “solution” to reconcile the two is:
  • be ruthless in making decisions about UX/functionalities for the “basic, out-of the box, plug-and-play” experience
  • be ruthless in paring down options and settings to cover 95% of use cases (or is it 80%? 99%? whatever %)
  • offer a second layer of settings for power-users or edge-cases and people who want to tweak very specific stuff; this wouldn’t be integrated in the interface that provides the “normal” settings, but probably more config-file-like
So in this case, if the team’s conclusion is that hashtag/category preview cards are the way to go, and that subcategories should display inline without mentioning the parent category, and that there isn’t sufficient justification to make this a general admin setting, it could still be a “hidden setting” accessible by adding “hashtag_preview_cards: OFF” or “show_hashtag_subcategory_parent_inline: ON” somewhere.
Writing this, I’m pretty sure there are dev implications in addition to UX regarding the multiplication of settings…
3 לייקים
Yes I understand people’s hesitation with adding the extra click here. @awesomerobot what do you think about this issue, do you think it’s worth adding a user preference around hashtag behaviour? Maybe if we had cards for tags and channels too it would make more sense to have an overall “Display cards for hashtags and mentions” user preference?
For mentions we could redirect to the user page on click if the current user has this preference turned off.
לייק 1
Just came across this myself and gotta say… not seeing the added value of the card preview either :grimacing:
I’m not a fan of adding more settings either so I would just vote to drop this altogether tbh. What are we solving here exactly?
לייק 1
To recap, some people find this too long inline, if I want to say “check out our Customization > Theme component category” it would be nicer is that was just “theme component” without the parent
but we can’t shorten it to just “theme component” because some sites reuse the same subcategory name across many categories and people want to see which parent category it comes from
the card proposal is to provide a bunch of category info on click, like we do for users, so we could use just the subcategory inline
I could go either way personally, sometimes I’ve found it nice to have the card because I can get quick access to the new topic button and see recent activity without leaving the current topic, but on the other hand I know some people just want the quickest path possible. I also don’t like the full category path inline.
2 לייקים
A use-case where avoiding to display the main category in the inline links occurs when subcategories are repeated across different categories, for example Announcements > Meetings and Support > Meetings.
I think that is resolved by showing different icons between categories, and the scope is refined from the posted text by itself.
Many users find the category + subcategory extension very uncomfortable, and I agree with that. Especially for mobile views, which make up a large part of the traffic we receive on Discourse.
לייק 1
@martin I think it’ll be easier to decide here once we fix the way mentions themselves are displayed.
The primary motivation here was to shorten these mentions: Customization > Theme component.
Let’s get that working properly first.
Then the value of these cards might make a bit more sense.
2 לייקים
Well it appears that the idea that I’d already done the hashtag shortening (getting rid of >) was a total figment of my imagination, it wasn’t in the existing PR :upside_down_face: Here is a followup PR:
2 לייקים
