העברת פורום XenForo ל-Discourse
Hey guys so after trying for a week or so I decided to import the database on docker app which I hoped it will succeed without any issues. TBH I got some issues at first but it turned to be all easy to solve.
Now I would recommend doing this only once before you deploy your production site, after importing everything take a Discourse backup, wipe everything out and install new Discourse instance then restore the imported db.
Ok let’s begin:
  1. First lets backup your old database from your old server, sign in to your Discourse server then:
     ssh USER@XENFORO_SERVER_IP  # Use -p argument to specify custom port
     mysqldump -u XENFORO_DATABASE_USER -p XENFORO_DATABASE_NAME > xen_db.sql
     exit
  2. After installing Discourse start the app:
     ./launcher start app
  3. Now lets pull the database backup from xenforo server:
     scp USER@XENFORO_SERVER_IP:~/xen_db.sql /var/discourse/shared/standalone/xen_db.sql
    If you changed the ssh port use -P argument
     scp -P 2222 USER@XENFORO_SERVER_IP:~/xen_db.sql /var/discourse/shared/standalone/xen_db.sql
  4. Login to docker machine, install and start mysql:
     docker exec -it app bash
     sudo apt-get update
     sudo apt-get upgrade
    During the installation you will be asked to set a root password for mysql
     sudo apt-get install mysql-server mysql-client libmysqlclient-dev
     service mysql start
  5. Login to mysql and create new database:
     mysql -u root -p
    Enter your mysql root password then
     create database xenforo_db;
     exit;
  6. Import your xenforo database into the new one:
     mysql -u root -p xenforo_db < /shared/xen_db.sql
     # Enter your mysql root password and wait until it finish
  7. Include the gem in discourse Gemfile:
     echo "gem 'mysql2'" >>Gemfile
  8. Run bundle install:
     bundle install --no-deployment
  9. Edit the importer script and change the following:
    vi /var/www/discourse/script/import_scripts/xenforo.rb
    XENFORO_DB = "xenforo_db"
    @client = Mysql2::Client.new(
      host: "localhost",
      username: "root",
      password: "Your mysql root password",
      database: XENFORO_DB
  10. You are set to go now, run the importer:
    RAILS_ENV=production bundle exec ruby script/import_scripts/xenforo.rb
  11. If you get the error 'Peer authentication failed for user "discourse"':
  12. Edit the file /etc/postgresql/9.5/main/pg_hba.conf
  13. change all ‘peer’ to ‘trust’ and save the file
  14. restart postgres server: service postgresql restart
Run the importer again and this time it should work without any problem, be patient this might take a while based on your database size.
Hope this helps someone. :slight_smile:
24 לייקים
What are the list of XenForo Data covered on this import?
I hope to import this list:
XenForo Page Nodes
  • Pages
XenForo
  • Profile Fields
  • Member Groups
  • Members
  • Status Updates / Profile Comments
  • Status Comments
  • Private Messages
  • Private Message Replies
  • Attachments
  • Member Ranks
XenForo Forums
  • Forums
  • Topics
  • Posts
  • Attachments
לייק 1
Got this error:
# bundle install --no-deployment
Don't run Bundler as root. Bundler can ask for sudo if it is needed, and installing your bundle as root will break this application for all non-root users on this machine.
Your Gemfile has no gem server sources. If you need gems that are not already on your machine, add a line like this to your Gemfile:
source 'https://rubygems.org'
Could not find gem 'mysql2' in any of the gem sources listed in your Gemfile.
לייק 1
Different Error now.
root@discourse-app:/var/www/discourse# RAILS_ENV=production bundle exec ruby script/import_scripts/xenforo.rb
No connection to db, unable to retrieve site settings! (normal when running db:create)
Traceback (most recent call last):
	31: from script/import_scripts/xenforo.rb:3:in `<main>'
	30: from script/import_scripts/xenforo.rb:3:in `require'
	29: from /var/www/discourse/script/import_scripts/base.rb:20:in `<top (required)>'
	28: from /var/www/discourse/script/import_scripts/base.rb:544:in `<class:Base>'
	27: from /var/www/discourse/lib/discourse.rb:411:in `system_user'
	26: from /usr/local/lib/ruby/gems/2.5.0/gems/activerecord-5.2.0/lib/active_record/core.rb:196:in `find_by'
	25: from /usr/local/lib/ruby/gems/2.5.0/gems/activerecord-5.2.0/lib/active_record/core.rb:196:in `all?'
	24: from /usr/local/lib/ruby/gems/2.5.0/gems/activerecord-5.2.0/lib/active_record/core.rb:196:in `each'
	23: from /usr/local/lib/ruby/gems/2.5.0/gems/activerecord-5.2.0/lib/active_record/core.rb:196:in `block in find_by'
	22: from /usr/local/lib/ruby/gems/2.5.0/gems/activerecord-5.2.0/lib/active_record/model_schema.rb:336:in `columns_hash'
	21: from /usr/local/lib/ruby/gems/2.5.0/gems/activerecord-5.2.0/lib/active_record/model_schema.rb:456:in `load_schema'
	20: from /usr/local/lib/ruby/2.5.0/monitor.rb:226:in `mon_synchronize'
	19: from /usr/local/lib/ruby/gems/2.5.0/gems/activerecord-5.2.0/lib/active_record/model_schema.rb:459:in `block in load_schema'
	18: from /usr/local/lib/ruby/gems/2.5.0/gems/activerecord-5.2.0/lib/active_record/attribute_decorators.rb:51:in `load_schema!'
	17: from /usr/local/lib/ruby/gems/2.5.0/gems/activerecord-5.2.0/lib/active_record/attributes.rb:234:in `load_schema!'
	16: from /usr/local/lib/ruby/gems/2.5.0/gems/activerecord-5.2.0/lib/active_record/model_schema.rb:466:in `load_schema!'
	15: from /usr/local/lib/ruby/gems/2.5.0/gems/activerecord-5.2.0/lib/active_record/connection_handling.rb:90:in `connection'
	14: from /usr/local/lib/ruby/gems/2.5.0/gems/activerecord-5.2.0/lib/active_record/connection_handling.rb:118:in `retrieve_connection'
	13: from /usr/local/lib/ruby/gems/2.5.0/gems/activerecord-5.2.0/lib/active_record/connection_adapters/abstract/connection_pool.rb:1008:in `retrieve_connection'
	12: from /usr/local/lib/ruby/gems/2.5.0/gems/activerecord-5.2.0/lib/active_record/connection_adapters/abstract/connection_pool.rb:380:in `connection'
	11: from /usr/local/lib/ruby/gems/2.5.0/gems/activerecord-5.2.0/lib/active_record/connection_adapters/abstract/connection_pool.rb:521:in `checkout'
	10: from /usr/local/lib/ruby/gems/2.5.0/gems/activerecord-5.2.0/lib/active_record/connection_adapters/abstract/connection_pool.rb:793:in `acquire_connection'
	 9: from /usr/local/lib/ruby/gems/2.5.0/gems/activerecord-5.2.0/lib/active_record/connection_adapters/abstract/connection_pool.rb:832:in `try_to_checkout_new_connection'
	 8: from /usr/local/lib/ruby/gems/2.5.0/gems/activerecord-5.2.0/lib/active_record/connection_adapters/abstract/connection_pool.rb:853:in `checkout_new_connection'
	 7: from /usr/local/lib/ruby/gems/2.5.0/gems/activerecord-5.2.0/lib/active_record/connection_adapters/abstract/connection_pool.rb:809:in `new_connection'
	 6: from /usr/local/lib/ruby/gems/2.5.0/gems/activerecord-5.2.0/lib/active_record/connection_adapters/postgresql_adapter.rb:40:in `postgresql_connection'
	 5: from /usr/local/lib/ruby/gems/2.5.0/gems/activerecord-5.2.0/lib/active_record/connection_adapters/postgresql_adapter.rb:40:in `new'
	 4: from /usr/local/lib/ruby/gems/2.5.0/gems/activerecord-5.2.0/lib/active_record/connection_adapters/postgresql_adapter.rb:215:in `initialize'
	 3: from /usr/local/lib/ruby/gems/2.5.0/gems/activerecord-5.2.0/lib/active_record/connection_adapters/postgresql_adapter.rb:684:in `connect'
	 2: from /usr/local/lib/ruby/gems/2.5.0/gems/pg-1.0.0/lib/pg.rb:56:in `connect'
	 1: from /usr/local/lib/ruby/gems/2.5.0/gems/pg-1.0.0/lib/pg.rb:56:in `new'
/usr/local/lib/ruby/gems/2.5.0/gems/pg-1.0.0/lib/pg.rb:56:in `initialize': FATAL:  Peer authentication failed for user "discourse" (PG::ConnectionBad)
לייק 1
Yay no idea how long this will take :smiley:
3 לייקים
This is correct right?
לייק 1
Guide needs an update I think.
Before running this, directory must be within /var/www/discourse/.
cd /var/www/discourse/
4 לייקים
3 posts were split to a new topic: XenForo import script imported banned users and soft-deleted topics and posts
8 posts were split to a new topic: Help migrating Xenforo
14 posts were split to a new topic: Issues while importing attachments from XenForo
5 posts were split to a new topic: Troubles moving from XenForo to Discourse
A post was merged into an existing topic: Troubles moving from XenForo to Discourse
Just gonna ask you guys why you move from xenforo to discourse? Im just started a forum a week now and i’ve seem xenforo runned websites and im impressed because of their plugins including pointing system. I just wanted the cons or reasons of moving. Thankyou
Just finished up a Xenforo → Discourse migration of a million post board on a Digital Ocean droplet. Here’s what worked for me command by command (very similar to what also just did on a different vbulletin board).
Recommend minimum 4 vCPU/8GB for import.
Thanks to everyone in this thread for helping me get through these migrations, definingly been a fun few days reading and rereading..
1 - Install Digital Ocean Discourse 1-click droplet
2 - Finish discourse install through SSH by following prompts
Open SSH console
root
(yourrootpassword)
(enter)
(yourdomain).com
etc
3 - Login to SFTP
sftp root@XXX.XXX.XX.XX
y (if asked for confirmation)
yes
(yourrootpassword)
put db.sql /var/discourse/shared/standalone/db.sql
4 - Login to Website to setup Admin account
5 - Login to SSH - Begin Process
ssh root@XXX.XXX.XX.XX
cd /var/discourse
sudo apt-get update
y
6 - Install MariaDB (replacement for mysql)
apt-get update && apt-get install mariadb-server-10.3 libmariadbd-dev
y
7 - Mysql Database Setup
service mysql start
mysql -u root -p
password
create database import_db;
exit;
8 - Import Dump → Mysql Database Transfer**
mysql -u root -p import_db < /shared/db.sql
password
9 - GEM File
echo "gem 'mysql2', require: false" >> /var/www/discourse/Gemfile
echo "gem 'php_serialize', require: false" >> /var/www/discourse/Gemfile
su discourse -c 'bundle install --no-deployment --without test --without development --path vendor/bundle'
(ignore red text result)
10 - Configure install script
---Make edits to text file as needed for db name/password, prefix, etc---
(esc)
:wq
11 - Bundle Config
bundle config set path 'vendor/bundle'
bundle config set without 'development:test'
bundle config unset deployment
su discourse -c 'bundle install'
12 - Mysql config (may be possible to do this with previous)
mysql --version
sudo mysql -u root -p
password
ALTER USER 'root'@'localhost' IDENTIFIED BY 'password';
FLUSH PRIVILEGES;
exit
13 - Install Script
su discourse -c 'bundle exec ruby script/import_scripts/xenforo.rb'
5 לייקים
I am in the process of trying to get this migration complete, however it seems to be throwing an error with the attachments.
Loading existing groups...
Loading existing users...
Loading existing categories...
Loading existing posts...
Loading existing topics...
creating users
Skipping 407 already imported users
importing categories...
       12 / 12 (100.0%)  [344731 items/min]
creating topics and posts
        2 / 4554 (  0.0%)  [17724 items/min]  Traceback (most recent call last):
        18: from script/import_scripts/xenforo.rb:396:in `<main>'
        17: from /var/www/discourse/script/import_scripts/base.rb:47:in `perform'
        16: from script/import_scripts/xenforo.rb:32:in `execute'
        15: from script/import_scripts/xenforo.rb:174:in `import_posts'
        14: from /var/www/discourse/script/import_scripts/base.rb:866:in `batches'
        13: from /var/www/discourse/script/import_scripts/base.rb:866:in `loop'
        12: from /var/www/discourse/script/import_scripts/base.rb:867:in `block in batches'
        11: from script/import_scripts/xenforo.rb:180:in `block in import_posts'
        10: from /var/www/discourse/script/import_scripts/base.rb:508:in `create_posts'
         9: from /var/www/discourse/script/import_scripts/base.rb:508:in `each'
         8: from /var/www/discourse/script/import_scripts/base.rb:509:in `block in create_posts'
         7: from script/import_scripts/xenforo.rb:186:in `block (2 levels) in import_posts'
         6: from script/import_scripts/xenforo.rb:315:in `process_xenforo_post'
         5: from script/import_scripts/xenforo.rb:324:in `process_xf_attachments'
         4: from /usr/local/lib/ruby/2.7.0/set.rb:328:in `each'
         3: from /usr/local/lib/ruby/2.7.0/set.rb:328:in `each_key'
         2: from script/import_scripts/xenforo.rb:326:in `block in process_xf_attachments'
         1: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.0.3.3/lib/active_support/core_ext/string/filters.rb:22:in `squish!'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.0.3.3/lib/active_support/core_ext/string/filters.rb:22:in `gsub!': can't modify frozen String: "\\t\\tSELECT a.attachment_id, a.data_id, d.fil\n\\t\\tFROM xf_attachment AS a\\n\\t\\tINNER JOIN xf_attachment_data d ON a.data_id = d.data_id\\n\\t\\tWHERE attachment_id = 13\\n" (FrozenError)
Does anyone have any thoughts on what could be going on here?  What is the "FrozenError"?
It looks like I had to edit the xenforo.rb file and change
# frozen_string_literal: true
to
# frozen_string_literal: false
2 לייקים
Thanks for writing this guide!
Does the importer also import avatars and attachments? Do I simply copy them to the /tmp/attachments folder?
From a quick look at the importer, it appears it only imports uploads to posts. Avatar support would need to be added.
2 לייקים
Can confirm. It only imports uploads. Avatars are not included. I just completed a Xenforo migration last week.
3 לייקים
Board size?
Post/threads/members.
Congrats :slight_smile:
2 לייקים
