הגדר VERP לטיפול בדואר אלקטרוני חסום
Setting up bounces handling
Discourse uses the Variable envelope return path (VERP) technique to handle bouncing e-mails.
To enable VERP, set the “reply by email address” site setting with an email address template that uses the + sign. The default of
replies+%{reply_key}@discourse.example.com
… works fine. If you are using your own or your company’s email server, then, that’s it :tada:
Your discourse instance must be able to receive email sent to this address. This should work via POP, but we highly recommend Direct-delivery incoming email for self-hosted sites
If, however, you are using a third party email service, you will need to enable VERP, or activate their webhooks as follows:
MailGun
  1. Log in to MailGun and go to your dashboard; look in the left column for the SendingWebhooks page.
  2. Select the Configuration tab and copy the HTTP signing key
  3. In your Discourse site, set the Mailgun API key site setting with your HTTP signing key
  4. Back in Mailgun, click the Add webhook button (selecting Domain-level) and set the HTTP post URL to https://your.discourse/webhooks/mailgun. Test this.
  5. Select both Permanent Failure and Temporary failure, double check the Domain, and then Create Webhook.
SendGrid
  • Log in to SendGrid and go to Mail Settings
  • expand the Event Webhook setting and enable it if it isn’t already
  • click edit to set the HTTP POST URL to http://your.discourse/webhooks/sendgrid
  • make sure you selected the following 3 actions: Dropped, Deferred and Bounced
  • save your changes by clicking the :white_check_mark:
MailJet
  • Log in to MailJet and go to event tracking
  • check the bounce event
  • set the endpoint URL to http://your.discourse/webhooks/mailjet
  • check the :white_medium_square: in the group events column
  • click the save button
SparkPost
  • Login to SparkPost and go to your dashboard.
  • Select Account from left menu icons
  • Select Webhooks from menu ( SparkPost )
  • Select New Webhook.
  • Enter a friendly value for Webhook Name e.g. Discourse Forum
  • Enter a Target URL as http://your.discourse/webhooks/sparkpost
  • Select Add Webhook.
Amazon Simple Email Service (AWS SES)
  • On Discourse:
    • set reply by email enabled and reply by email address as per the top of OP
    • set manual polling enabled
  • On AWS:
    • create an SNS Topic
    • create an SNS Subscription for the created Topic as HTTPS pointing to https://your.discourse/webhooks/aws
    • go to SES > Verified Identities, select your site domain, and go to the Notifications tab. Edit your Feedback Notifications. Set the Bounce feedback and Complaint feedback to the SNS Topic you just created
Postmark
  • Login to Postmark and then select the server that is used for sending Discourse emails
  • Select the message stream associated with Discourse emails, typically Default Transactional Stream
  • Click Webhooks
  • Click Add webhook
  • Enter Webhook URL as http://your.discourse/webhooks/postmark
  • Under, Which events should we send?, check Delivery and Spam complaint
  • Scroll down and click Save webhook
Testing Bounces
To ensure that everything is working, do this:
  1. Sign up for a new account on your site with an obviously incorrect email, of the form bademail@obviously-invalid-domain.com or clearly.nobody.has.this.email.address@gmail.com
  2. Wait a while for the emails to fully bounce (check your provider’s logs, if you want – they will usually be shown under the “warn” or “error” log level)
  3. Check /admin/email/bounced on your site to confirm that the bounce was picked up. Bear in mind this may take up to 48 hours depending on how many retries and the particular logic of your email provider.
Configuring Bounces
Bounces handling can be customized using these site settings
  • soft bounce score: points added to the user’s “bounce score” when we receive a temporary bounce from their email address
  • hard bounce score: points added to the user’s “bounce score” when we receive a permanent (or unknown) bounce from their email address
  • reset bounce score after days: number of days during which we must receive no bounce before we can reset the user’s “bounce score” back to 0
  • bounce score threshold: score threshold at which point we will stop sending non urgent emails to the user
Last Reviewed by @SaraDev on 2022-07-19T20:00:00Z
51 לייקים
Does Discourse use Mailgun's validations feature?
VERP bounce replies ignored when using Mailgun
Postmark bounce support?
Email-in replies thread wrongly
Amazon SES/SNS email complaints not received, bounces missing information
What mail service do you recommend?
Confused about VERP, email bounces & additional setup on Discourse
Reply-by-Email was working, now broken
Mailgun "temporarily disabled due to high bounce rate"
How to deactive account of those users who're not receiving emails
Surface data about users with too many bounces
"Discourse::NotFound" error when click "Email Type" field on admin/email/bounced
Configure direct-delivery incoming email for self-hosted sites with Mail-Receiver
Bounced Email Info Not Found
Fix AWS SNS Bounce
How to block outgoing emails to at anon.forumurl?
Mailgun api key check backward (no API key should be required if bounces handled by mail receiver)
Switching from SMTP to oAuth
Is handling bouncing emails optional, or is it something I definitely need to set up?
Moving from Mailgun to Amazon SES as an amateur
Mailgun api key, what is it for?
Question about the mail-receiver
Goodbye Sparkpost
Migrated forum with many invalid (bouncing) emails
Amazon SES API - How to setup?
Zero entries in bounced email list
Email suppression list handling
How hard is it to handle Discourse after installation
Set up mail-receiver, but now site won't send any emails?
Installation by the book
Too many user emails domains not working lead to mailgun domain disabled: what to do?
Mailgun huge dropped subscriber
Flush bouncing user mail address
Configuring AWS SES for outgoing, bounce, and incoming email
Notes on Silencing or Deleting users
Retrying bounced emails?
Discourse Mailgun Routes
If someone wants to test this out and confirm that it works, I’ll add it to the OP.
Create Mailgun webhooks
for event_type in 'permanent_fail' 'temporary_fail'; do
curl -s --user 'api:'=mg_api_key= \
          https://api=mg_region=.mailgun.net/v3/domains/$discourse_hostname/webhooks \
          -F id="$event_type" \
          -F url="https://=discourse_hostname=/webhooks/mailgun"
done
Updated the Mailgun section as things have changed a wee bit in their UI:
4 לייקים
Is there a simple way to handle email complaints automatically currently using VERP? For the case of users who do not unsubscribe but just mark the email as spam. It’s quite critical to stop emailing people who complain.
2 לייקים
Just kind of FYI to everyone with low level skills: SES part is badly outdated, I reckon.
Just don’t choose FIFO even it is suggested :man_facepalming:
לייק 1
Hi @pfaffman , thanks for sharing this but quick help please
what if I’m using another email provider rather than the previous list is it still possible?
2 לייקים
In my logs, the endpoint webhooks/mailjet produced a warning:
Received a Mailjet webhook, but no token has been configured. This is unsafe behaviour and will be disallowed in the future.
In /admin/site_settings/category/email?filter=mailjet there is the “Mailjet webhook token” field, with no instructions on how to correctly set it up.
I went to Mailjet and added to the Endpoint URL field: https://discourse.example.org/webhooks/mailjet?t=[your_token]
I replaced [your_token] with one generated by a Token Generator, and entered the same value in the “Mailjet webhook token” field at /admin/site_settings/category/email?filter=mailjet.
That appears to have eliminated the log warnings.
לייק 1
Just wanted to note, that I have confirmed that spam complaints for AWS SES are sent from complaints@email-abuse.amazonses.com to the ‘Reply by email address’ (in Discourse settings) and are treated as hard bounces by Discourse currently via the standard VERP configuration (without SNS webhooks).
Just found this, which might be useful to some using SES also (the ‘Using the mailbox simulator’ section):
Can use the ‘send a test email’ inside the Discourse admin to send to specific addresses that will simulate things like bounces and complaints without hurting your sending reputation.
e.g.
bounce@simulator.amazonses.com
complaint@simulator.amazonses.com
There are other testing addresses in the link above.
לייק 1
Just updated the Mailgun section as things have changed a wee bit again (for the better!).
