500 Error Postgresql
I have been getting 500 Errors on my forum recently. A rebuild fixes them.
This is what the log says:
could not connect…
/var/run/postgresql/.s.PGSQL.5432
What can I do to fix this? Or where can I find out more as to what causes the error.
Any help much appreciated.
So you have enough ram?
Your big is your database? How much ram? How many users /page views?
Hi Jay,
4GB RAM /80GB DISK, Digital Ocean hosting. We have about 700 users. Page views yesterday 273, normally in the region of 100-600 per day. The size (going by the backup size) is 1.1.gb.
And yes: Digital Ocean console reports a lot of Out of Memory errors. I though my site was pretty small and should be fine with the above specs? Maybe I should go to 8gb, double the price at Digital Ocean…
No need to resize the droplet, it is more than enough, you should run the discourse-setup to be sure the settings are alright:
cd /var/discourse
./discourse-setup
Don’t worry, you won’t lose anything, it will only redo the app.yml, but save a backup just in case before.
