504 Gateway time out
(Jeremie Leroy) #1
Hi all,
It was all working great and this morning I encounter this :
i don’t know where to start to fix this, Should i switch off and back on the digital ocean drop let ?
#2
Its better to first login to the server using SSH and check what’s wrong before doing a reboot.
#3
If you want me to have a look at it for you - ping me. I can help.
(Jeremie Leroy) #4
thanks @nixie, i reload, just switch off and on and it now works. Quite scary though, thanks for your help nixie, will know for the next time if happen and send you an ssh screen shot.
Best,
#5
No worries.
But, its always a good idea to “find what caused the issue”, before fixing it. This will help us prevent it from happening again in the future.
(Jeremie Leroy) #6
yes, i will try to be better on this, sorry I’m still quite a newbie but working on fixing this too :wink:
