Using Safe Mode to troubleshoot issues with themes and plugins
:bookmark: This guide explains how to use Discourse’s Safe Mode to troubleshoot issues with themes and plugins.
:person_raising_hand: Required user level: All users
Discourse offers a “JavaScript Safe Mode” that allows any user to isolate the root cause of JavaScript issues caused by plugins, themes, or theme components. This feature is particularly useful for troubleshooting problems on your Discourse site.
Accessing Safe Mode
To access Safe Mode, follow these steps:
  1. Open a new browser tab.
  2. Enter the following URL in the address bar, replacing [your-site-name](http://discourse.example.com) with your actual Discourse site domain:
    http://discourse.example.com/safe-mode
    For example, the Safe Mode URL for the Discourse demo site is:
    https://try.discourse.org/safe-mode
  3. Click the ‘Enter Safe Mode’ button:
Safe Mode options
When entering Safe Mode, you can select from the following options:
  • Disable all themes and theme components
  • Disable unofficial plugins
  • Disable all plugins
By default, all three options are selected. However, you can enter Safe Mode multiple times with different combinations to isolate the specific component causing issues on your site.
Using Safe Mode
  1. Select the desired options on the Safe Mode page.
  2. Click “Enter Safe Mode” to apply your selections.
  3. You will see a banner indicating that Safe Mode is enabled.
  4. Browse your site to check if the issue persists with the selected components disabled.
Exiting Safe Mode
To exit Safe Mode, simply close your browser tab.
Important notes
When sharing a Safe Mode link for your site, be aware that it needs to be opened in a new tab or added directly to the address bar; otherwise, it may not work correctly.
:warning: Safe Mode currently only disables the JavaScript portions of plugins. To disable the server-side portion of a plugin, you must rebuild your container with the plugin commented out.
Troubleshooting
If you cannot load the initial Safe Mode selection page, try visiting the following URL, which will skip the page and load Safe Mode directly:
https://discourse.example.com/?safe_mode=no_themes,no_plugins
For example: https://try.discourse.org/?safe_mode=no_themes,no_plugins
:information_source: On Discourse versions 2.9.0.beta8 and below, you need to use ?safe_mode=no_custom,no_plugins instead.
Broken upgrade - forum down, unhelpful error
Admin Plugin page is blank - Error: There is no route named adminPlugins.index
502 and then empty forum after `./launcher rebuild app`
Upgraded last night and login button no longer works
Content of messages not showing up
Old "chat" button on Plugin admin page
Topic Preview Broken (due to Google PageSpeed Module)
Uncaught Errors
"About" pages crashing our Discourse
The composer needs to be more friendly to iPad Mini
Manually Clear DistributedCache
Browser too old message when "compatibility mode" is forced in IE 11
My site just broke after restarting server
After Recent Upgrade to 1.08? beta - No forum shows
Blank topics after import?
Problems clicking topic links in IE11
Double but offset lines in edit box
Website looks different on different browsers
How to disable a component without access to site?
Cannot create new topics (already disabled plugins)
Scrolling posts "jumps" back up when reaching end
How to increase site speed
Upgrade from within China fails due to git issues
Disable plugins without restarting?
Updating / Rebuilding Discourse to latest version irreversibly breaks website
A "safe mode" to easily disable all third party plugins
Discourse and Uncaught ReferenceError: ClipboardJS is not defined
Beginner's guide to using Discourse Themes
Global notice doesn’t show
Incorrect initial order when user sorts topic list
Unable to expand profile
Disable plugin without downtime?
Like button does not work on archived topics
Mobile Header expanding after tapping hamburger menu
Discourse 2.3.0.beta10 Release Notes
Lightbox not showing up on uploaded images after update
Vimeo onebox not working
Pasting tables from spreadsheets no longer working after 2.3 upgrade
Contains_dtoc in Grey Amber theme header
Site fails to load with js errors
No content displayed on front category page after upgrade
Notifications are acting strange
Occasional page loads with no post content due to plugins
Discourse 2.5.0.beta2 Release Notes
LDAP Setup for Discourse
Unable to add/edit tags
Category unlike any other category
Unable to save wiki update
Infinite scroll not working in "Latest" on Mobile
Disappearing posts in 2.1.0.beta2
Post content not showing up
In-post links to topics - no longer update to the initial posts title
MacOs users on old version can´t read posts
Issue with menu, admin
Excerpts truncating at 50 characters
How to change default Discourse theme via CLI?
Rtl direction is broken in quotes
Mentions reported wrongly as replies in notifications list
After recoverying a Backup file on new "On-premise" VM - Site no longer works
Bad JS customizations - how to fix in the backend?
User Notes plugin is breaking my site
Send Invites button should not be visible if local logins are disabled
Fields overlay text in login
No Profile Header or User Card Background in /preference/profile?
Blank page after theme installation
Topic-footer buttons are disappearing
Red sticky warning for admins ⚠️ (este mensaje solo lo ven los administradores del sitio)
Blank pages, 500 errors and no logs
[2.1.0b6] New topic button is moving behind burger on click
Problem with displaying personal messages in Dark
Google, Twitter and Facebook Logins not working due to ad blocker
Can't See Posts When Logged Out
"Quote" button disappears after navigation
After latest admin/upgrade my Admin dashboard won't load
My install was broken because I upgraded but did not upgrade plugins
Bulk edit icon not showing?
Quoting is not working anymore
Category drop down not truncating ... for longer category names
Some user see a blank page when opening a topic
Error occurs when clicking on the user profile picture within the post
Admin Trouble Creating a Category
Browser Back Button issue
Issue when zooming large image in lightbox on mobile
Topic mismatch troubleshooting
Edit icon not activating after edits
I don't see the staff wrench on posts
Forum does not work for users on iOS
Category autocomplete stopped working on our site?
A topic doesn't open with recent upgrade due to a plugin
UI not loading after git pull update
Chat problem on mobile devices with 3.1.0beta5
Gui for querying category of solved or unsolved topics
Image displayed incorrectly on Mobile due to theme settings
Preview of post not loading because force https was not set
After updating to "2.9.0.beta1", the number of clicks on the image URL is not counted
Reordering Categories Produces Error 422
Limit on Number of Child Categories?
Password reset landing page not loading because of cloudflare rocketloader
Invites not populating Invite URL
"Something went wrong" when liking posts using hearts
Issue in user summary
Lightbox for images comes by default?
Updated discourse and now site fails to display
Before there was an icon in my text box where I could send images, gifs and videos
Having an issue with images' width getting cut off on desktop
Issue with the page title in Arabic?
Latest update broke my forum
Clicking on a category doesn't filter the right topics
Registration modal/popup not showing up for private instance
Iframes Not Working
500 error on category view mobile due to knowledge base plugin
Direct links not loading for certain users, detailed explanation included
Topics tagged with `info` have strange appearance
Missing scroll bar slider, in Finnish Localization
Server errors in 2.5.0.beta3
Undefined column 'boomarks.post_id' after update
Deleting group with 404 error
Multi-site upgrade leaves _some_ sites unavailable
Logins redirects to missing notifications page
Plugin admin section
Discourse broken after upgrade
Topic Will Close A Few Seconds After The Last Reply
Can't add tags while editing a topic
Unable to edit tables
Usercard Redesign Experiment
Issues with index page infinite scrolling?
How might we better structure #howto?
Plugin page not loading unless I hard refresh (Chrome)
Column bookmarks.topic_id does not exist
Better error pages?
Basic login help needed
Featured Tiles
Redis Problems? (Forum broken after upgrade)
Hashtags with numbers in parentheses appearing everywhere on Discourse site
After updating to 2.8.0.beta8, nothing shows as "read" anymore
Breaking Mobile view check after Discourse update to 2.5.0.beta7
Bug with access to public topic without login 3.1.0.beta2
Dashboard empty since upgradeto 2.5.0
Can’t create new category
Login form missing entirely from Discourse instance
Mobile devices cannot display the interface correctly
Category link failed after updating today
Weird Formatting Bug in old Microsoft Edge
There is no content in Preview Summary. Where should I configure the content and style of the digest?
Blank website after update
Content won't load after update
Category Icons
Error 500 on category page and homepage after upgrade to 2.6
Mouse click is not working in my forum after recent update
Screen black out bug on modal
Social share components do not appear
Admin panel does not work
Totally blank upgrades page
Accidentally overwrote application.hbs || Enter safe mode
My Discourse site is not loading due to misconfigured CSP
Latest beta update (2.7.0b7) gone wrong
Some topic category boxes are missing
Need help reverting forums. I made a mistake
Pups::ExecError: su postgres -c 'psql discourse -c "alter schema public owner to discourse;"' failed with return
Can not access Discourse - blank page
Display issue in the "hide details" element
Topic replies are not displaying in chronological order?
Site broken after update
The "Save Changes" button is very low on my user preferences interface page
Uploads timing out or very slow
Problems when logging in as admin
Scroll jank when scrolling up
Phantom signups (two users with the same account after migration)
Composer overflows when open
Homepage (sub)category display - lots of whitespace
Category Image Formatting
Username autocompletion not working with special characters?
Update problem help pls
Flagged chat comments appearing oddly / not appearing in review queue
Restarted VM; now `/admin/upgrade` page fails to load, JS requests fail, some avatar images 404ing
Bug on topic interface after an update || Resolved
Upgrading from 2.9.0.beta8 broke the site, unrecoverable
MacOS Firefox image upload error
504 Gateway Timeout for some reports
Repeated content and infinite loop
Trust level 1 users cannot Invite
Error: Something went wrong - "Error while processing route: discovery.categories"
Loading groups gives internal server error
UI not rendering in Chrome/Firefox due to CloudFlare rocket loader
"Reply" button appears even on closed topics when logged out
Private Message Can't Be Reached with private messaging disabled
Sidebar has disappeared
Double new topic banner
[2.7.11] tags notifications dont work anymore for regular profil
My Discourse Forum can't display images
Themes tab not showing up in the customized tab
Upgrade page empty
Can't rebuild due to theme errors
Application crash due to invalid imports
Topics preview gone - upgrade from 2.6 to.2.9
Width of page causes an autoscroll to the top of the page when accessing serach/user/hamburger comboboxes (chrome only)
Jittery scrolling behavior
"Add required tag group" not working for a new category
Search Bar pops up when adding new topic or replying
Spurious "Draft is being edited in other window" errors
iOS desktop view on ipad shaking at bottom of topics after zooming
Screen jumping around on mobile
Search results for Replit Forums not linking properly
Upcoming events shows 500 server error
Mixcloud Embeds have stopped working
"Watched words" review queue seems broken
The first emoji inside a title is not in the same "code" and is bigger
How to fix problem with CSP
Error: Can't access property "registerAsyncHelper"
Hamburger menu not showing on mobile?
Pasting a Youtube playlist link in the title doesn't fill the title and post content
Fast edit doesn't work on content with certain characters
Lightbox not working on Discourse
Thumbs up, twice
Category image upload stops at 0%
Javascript error if emoji_autocomplete_min_chars setting > 0 for each character typed after a colon in the composer
Horizontal loading slider
Iframes Not Working
Polls broken after update
Little crack when sliding on Iphone
User preference persists through Safe Mode
New topic mobile CSS corruption?
Updated discourse and now my spacing is off
Hide who's replying to this topic
Forum Completely Broken 2.8.5
Mobile view editor cog dropdown issue
How many category moderators are shown on about page?
"Posts may not display correctly because" seeing this error in new discourse installation
The notification bar could not load
MathJax plugin is not working. Safe mode works. Workaround, disable MathJax plugin
Trading Buttons
Category logo image overlaid by text after recent update
Post Preview not working because of events plugin
Site not loading and breaking after doing upgrade from admin UI due to theme errors
The "Hide Details" feature doesn't show up correctly in the preview window
Category missing (only showing posts per month) when not logged in
Post delay - 2 post
Personal Message Bubbles
Giant flashing edge/cursor on Latest view
Images being cropped on mobile
Unable to create categories - No creation button for admin or moderator
TypeError: Cannot read property 'id' of undefined
Text editor is not working in Firefox 78?
Issues with search on meta
Prevent anons from downloading files incompatible with CDN
What on earth is causing this?
Composer does not work properly when repling on Firefox
"all categories" button and "open draft" button outline is weird
Users cannot check discourse
Topic links from the “latest” topics list don’t always scroll to the last read post
IP Lookup UI is broken
While loading a new component on the site, the site is down
Unable to reply on original topic
The composer gets stuck under the header if dragged too far up
"Review" disappeared from top-level menu
My forum stuck on blank page without content
Pop up - how to css?
Latest update gives blank screen on mobile
Discourse unresponsive in Chrome
Welcome to forum message and Staff notice removes welcome icon
Server reboot necessitates disco container reboot
Help! Tried to install a plugin and now my forum is missing
Plugins not visible on /admin/plugins
How to create a theme which only administrators can use?
User info pop-up disappears
Published page not visible?
After restoring a backup, discourse is 'loading...' and broke
Time window pulldown on meta start page, but not on local instance?
TypeError: r is not iterable
Staff having trouble accessing deleted posts via the counter link at the top of user profiles
Are there updated directions for moving posts?
Accidentily deleted the main sidebar section
All groups are not anymore displayed in group page
Discobot didn't recognize link in tutorial
No Gear Icon Menu for Moderator [iPad]
"Failed to Fetch" GIF TypeError (From the Offical Discourse Website)
Embedded Youtube videos sometimes need to be clicked twice to start playing
Code Highlighting with Escaped Quotes
Why is the Sidebar Collapse missing on my site?
Popular Topics | By Default Today
CMYK scheme in Consolidated Pageviews graph
Inserting Javascript yields 403 error
Topic hangs on mobile
Search results page displays topics title that I cannot click
Converted topic posts to message can not convert back to topic
Add site setting to not show "Invited by" on user profiles
Bulk Action ‘Append Tags’ not working when tags are restricted
Links in Logs have a blank href
Our discourse overload because of a custom plugin. Please help me
Issues with site on Linode because domain’s registration had expired
Text glitch on my forum
About the user fields arrangement problem
My forum is stuck on the loading screen
Safe-mode failed with a plugin
Popup message and Text customization issue after upgrade
Minimize-Close Button Missing
Can't close user notes modal due to deprecated guest gate plugin
Build Poll is not shown from gear menu for new topics
Review section not found
After upgrading to discourse 3.. can only access to admin using safe-mode
Attachments: Oops! That page doesn’t exist or is private
Globe icon at sidebar behaves badly
Attempted to upgrade and I think I messed something up
Prevent users from moving topics in other categories
Description from a category page when the category has an image disappear when navigating
System account login
How can I enable: Auto-hyperlinking text to reference to other posts?
Clipboard copy from theme text editor only copies about a one and half lines of text
Not able to enter info on /admin/plugins/rss_polling page [ad-blocker]
Infinite scroll does not work on All Categories page
Error loading the individual group when using allow pm to staff plugin
Svg mobile logo scales incorrectly
Notification issues
I have added some js code to themes head-tag from backend. I want to delete the code but cant accees backend now
Granting custom badges is not working
Are flags no longer showing up as red?
I cant see bulk actions in my discourse installation after selecting items
Existing category invisible on page but visible when re-ordering categories
"Unlikable" posts can be liked using keyboard navigation
Error when trying to view "Your Votes" with Topic Voting plugin
Custom sidebar sections being tested on meta
Discourse not available
User cards for anonymous visitors immediately dissappear with "500 Internal Server Error" in `card.json?include_post_count_for`
Data explorer group report - parameter bug
BBCode `url` tags break if wrapped text ends in URL with component after host
Create account window squished
If a Wiki post is editable by non-staff, shouldn't there be an option to allow those who can edit the post to see all the edits to it?
Javascript alert/popup message when entering site
Fedoras Discourse instance made some troubles. Could the support please give some feedback
Add Preference for sidebar vertical scroll
Minimizing Maintenance on Theme Customizations
No editor preview while editing after upgrading to 3.x
"Like this post" not available for some categories
Search no longer works after 3.1.0.beta1 update
After update, site won't come up
Tag section and All Tags link not visible on the sidebar unless a default tag is set
Hosted site stuck on loading page (colored dots) (01/18/2023 8:05 AM Eastern)
Discourse not launching after upgrade
Streamable - whole file is downloaded on mobile version
Drag'n drop cause crash browser tab
Reports is not loading
Composer previews not working in Safari
Notification bubble missing from top right profile pic
Cursor jumping around in composer / editor text box
Discourse now stops loading at login dialog when viewed with any browser
Error: Users can't make new accounts
Assign plugin: Note not visible
Save Category does not work in Categories setting
Composer handle can be dragged up behind the site header on touchscreen devices
Hide topic timeline
Modal headers - seeing double
How to customize the dashboard?
Getting a 500 error on the mobile for bookmark and some category pages
Polls, Spoiler, Details, Calendar, etc menu options missing
Discourse's CSS variables aren't set
Forum stuck on the loading home screen
Discourse Comments stuck on "Loading..."
Blank screen when adding categories to the navigation menu
The bulk tools for PMs have been removed after last update
Avatar in rtl website in wrong place
Sorting parameters incompatible with one another
Unread & New not clearing from Categories
Announcements posts are deleted... won't undelete
“New topic” button working incorrectly
Preview quoted avatar images flicker in Safari
Profile picture (avatar) and site setting uploads are not working
Staff category permission change
Cannot see take action options on mobile
Provide option to choose showing full names in chat
Published/Scheduled Posts 'Watching First Post' notifications not being triggered
Quote-feature occasionally missing on Android
Chat button on usercard
router.transitionTo gets aborted only for chat page, but works for the rest of the links like users page
Broken width responsive mobile
Our PMs stopped working
Permanent deletion: Function not available
Quote button on hover is missing
What Themes are being used for these Discourse forums?
Ignore user date range seems buggy in Safari or Firefox on touchscreen desktop
No keyboard when adding tags while editing a topic
The "more" menu option for About, FAQ, Badges, Groups is missing on Safari with macOS - but only when logged in
Login popup not display
Back button on CSS editor is not working
Blank entry in recent searches
Server 500 Error on "Emails > Preview Summary"
User cannot see newer topics
The user cannot see his personal message
Category is missing from latest
Errors in console related to loading account preferences route directly
Discourse use double nginx error : Could not find module `handlebars` imported from `discourse-common/lib/raw-handlebars`
Can't upgrade user to admin - unhandled server error
/?status=deleted filter crashes browsers
Error 500 after succesful app rebuild ( asset ".js" is not present in the asset pipeline.)
Save button on profile page disappears with Calendar plugin
Event date is no longer styled in topic list (mobile view)
Modal is set to display none;
Performing bulk actions as a moderator
429 Error when scrolling too fast on Leaderboard
Staff can see custom navigation menu group editor
My forum stays on the loading screen "Could not find module `virtual-dom` "
Where to find standard supported dark theme?
Easy Responsive Footer Plug-in bug issues
'qa-topic-tip' Ember is not defined error
Spacing on mobile when on latest view
New Group - 500 Error
Leaderboard reloads and repeats
Image preview gets cut off
Discourse startup issue
Inline formatting used when "preformatted text" formatting applied to multi-line selection
Site stopped working "without reason"
Overlapping text and menus after upgrade to 3.2.0.beta4-dev
I can't display my policy
User profile links redirect to 404 page
Customise Page Settings unresponsive on Mac OS
Problem with api version when updating docker manager
No access to backup page
Black hole in Sub-Category
After upgrade, unable to go in discourse
Text selection is cancelled when the AI popup disappears
Preview scrolls to the bottom after editing a post
Moving the server
Page keeps loading after update
Positioning issues with RTL locales after recent updates
Log in button on Subscription Page does not work
Reply button doesn't work any more after recent update
Entire site is a blank page after upgrade
Unable to reply due to javascript error [Quick Quote theme component]
The Missing Public Profiles Mystery [Animated Avatars]
No user preferences updating on my site
Cannot Create New Topics
Problem with Chat in fullscreen mode
New Discourse Lightbox Enabled on Meta - now disabled
Forum broken for Admin - Assets missing?
Topic embed and import don’t validate for 0 character titles
Where is, "top" on category views?
Refreshing everytime I open a topic
Uncaught SyntaxError: forum spins nonstop and never loads
Settings opens showing black
Collapse Button Not Working on Profile Page (Mobile)
How to Get Rid of a Faulty Plugin?
Users can post to forum on PC, but not with mobile
"Add User Note" no longer shown in "post admin options" menu
Hide parts of a post
Redirects on load remove URL parameters
The "community" tab is no longer visible in the sidebar
After rebuilding app, can't sign in with error 500
Copy quote functionality
Blank topics after log-in (Patreon cookies)
Webhooks fail to run, webhooks settings page returns 404
Discourse forum wont load any pages whatsoever
Set Slow Mode return a 403 error - I am administrator
UI crashes due js translation error
Template list takes 5-10 seconds to load
Labels broken in the Consolidate Pageviews graph
Board unaccessible after upgrade
I get "500 error" error while editing post
Cannot login as administrator after latest update
Bug with avatar of all staff are default icon while custom one is uploaded
All links to categories broken?
Images not appearing after domain change
Issue in uploading media files
Keyboard and mouse stopped working + content-security-policy error
Category-selector.js:73 - Uncaught TypeError: this.attrs.onChange is not a function
Bold/Italic Words Being Put On Separate Line
Update = :skull_and_crossbones:
`white-space` CSS property of clipboard data not respected when pasting in rich text editor
Discourse broken after moving servers
Dragging highlighted texts causes Chrome freeze
Client-side vs. server-side?
Can't get Ruby to update so ./launcher rebuild app keeps failing
Base_path not being substituted in some cases
Edit CSS/HTML of custom theme not appearing
Finding Discourse RSS feeds
500 Error when posting, moment.tz runtime error
Some DMs are not visible
Air Theme Latest Update - Crash
Dashboard New Posts statistics broken
The order of characters when typing in the floating search widget is reversed
Floating search box cannot be closed when device goes from horizontal to vertical
I'm getting errors when I switch categories too quickly
Inline “preformatted text” formatting used when multi-line selection doesn't contain hard break
Coincidental Markdown in formatted content pasted to rich text editor rendered on publish
Category settings broken
Spurious notification when navigating away from review queue after adding note
Links produced by the Composer link modal break when they contain a ' (%27)
Only loading HEAD after upgrading docker, due to Babble plugin
Made some changes I cannot revert
Using Cloudflare for HTTPS, empty preview pane in edit page
Writing an effective bug report
Avatar settings not visible with SSO
Emoticon button not working anymore (because of babble plugin)
Stable broken due to discourse-spoiler-alert
How to disable a plugin when admin plugin page is not loading
New topic and reply not working
Front page of discourse missing content
Messaging drop down menu not working
Somehow, for me those links only work when I open them in a new tab or window. The first one leads to the oops page and the second one to the homepage. But the safe-mode banner does not appear. The second one can lead to problems when you send a link to a user to let them try safe-mode. If they just click the link, they will still use the site without safe-mode.
Maybe this information should be added to the how-to.
Good catch -both links are borked. The first needs a ? and the second needs a comma instead of %2C
Where does it need a “?”?
Could you share the link as an example?
Oh, sorry, it looks like I’m wrong on the first one: the internal navigation fails, but for a new window it works.
Discourse Meta
And I’m wrong on the other one too! Discourse Meta - The Official Support Forum for Discourse
doesn’t work as a same-page navigation.
My mistake: something is broken, but it’s not the URLs.
I think it’s because it’s trying to open them in place. Rather than argue with it I’ve swopped them out for try.discourse.org. :slight_smile:
I think somehow admins should still be informed that sharing those links can easily be a problem.
For example, I report an issue on meta. You could ask, “Could you try https://meta.discourse.org/safe-mode?” Then I would tell you that the link does not work.
Or even worse: you want to specify that I disable only themes, so you ask me to try https://meta.discourse.org/?safe_mode=no_themes. My problem still exists. How are you sure I really used safe-mode? As a user, I think it worked because something happened when I clicked the link.
After I posted here, you know about this. But how do other admins know they have to pay attention that this could be a problem?
I’m wondering, due to the nature of this safe home page displayed (that replaces all the content), if an exception should be made to open this link to a new tab.
I’ve added a note and also a screenshot of a ‘successful’ one. How does that look?
3 posts were split to a new topic: Should safe mode be default off for non-staff users?
