Discourse Math
:discourse2: Summary Discourse Math uses MathJax (default) or KaTeX to render maths in your Discourse forum.
:open_book: Install Guide This plugin is bundled with Discourse core. There is no need to install the plugin separately.
Enabling Math
The Math plugin can be enabled from its settings, accessed from your admin/plugins page:
Math settings
Features
Once enabled, you can render inline math by wrapping with a single $ like so: $E=mc^2$.
You can render blocks of math by wrapping with $$
\sqrt{(-1)} \; 2^3 \; \sum \; \pi
Discourse Math uses a heuristic to ensure that sentences such as: “I spent 20$ and another 100$” do not get converted.
LaTeX Delimiters
When enabled via site settings, you can also use standard LaTeX delimiters:
  • Inline: \(...\) - Example: \(E=mc^2\)
  • Block: \[...\] - Example:
    \frac{1}{2}
AsciiMath (MathJax only)
When using MathJax, you can enable asciimath processing which uses % as a delimiter: %E=mc^2%
Composer Integration
The composer includes an Insert Math button in the toolbar with keyboard shortcut Shift+M. This opens a modal where you can:
  • Toggle between inline and block mode
  • Write your LaTeX expression
  • Preview and insert into your post
In the rich text editor, math expressions appear as editable nodes with an edit button to modify the expression.
Chat Support
Math expressions are also rendered in Discourse Chat messages using the same settings and rendering engine.
Rendering Engines
MathJax (Default)
  • Version: 4.1
  • Output formats: HTML (default) or SVG
  • Features:
    • Contextual menu (right-click on math)
    • Accessibility enrichment for screen readers
    • Zoom on alt-click (175% zoom)
    • AsciiMath support
KaTeX (Alternative)
  • Features:
    • Fast rendering
    • Mhchem extension for chemical equations
    • CopyTex extension - click math to copy LaTeX source to clipboard
    • Cross-reference support with \label, \ref, and \eqref macros
Site Settings
See all relevant site settings by searching your admin settings for “math”.
Name Description
discourse math enabled Enable Discourse Math plugin (adds special processing to $ and $$ blocks)
discourse math provider Math rendering provider: mathjax (default) or katex
discourse math enable latex delimiters Enable LaTeX-style delimiters: \(...\) for inline and \[...\] for block math
discourse math mathjax output MathJax output format: html (default) or svg (MathJax only)
discourse math enable menu Enable contextual menu for math expressions (MathJax only)
discourse math enable accessibility Enable accessibility features like text enrichment (MathJax with menu only)
discourse math zoom on click Zoom 175% on alt-click interaction (MathJax with menu only)
discourse math enable asciimath Enable asciimath processing with % delimiter (MathJax only)
:discourse2: Hosted by us? This plugin is available on all of our hosting tiers Math | Discourse - Civilized Discussion
2 posts were split to a new topic: Add support for email formatting of mathjax
2 posts were split to a new topic: Can Mathjax be upgraded to Version 3?
6 posts were split to a new topic: Add support for Latex style blocks and inlines for Math
A post was split to a new topic: Equations do not render properly in blocks
A post was split to a new topic: Math not rendering in Preview
15 posts were split to a new topic: Math and AI workarounds
26 posts were split to a new topic: Upgrading Mathjax to version 4
Just a quick (positive) real-world note after moving to the newer MathJax (v4.1) integration in Discourse Math.
One quality-of-life improvement I’ve noticed is that MathJax now gives very specific, localised feedback when input is invalid or a macro isn’t defined:
  • It still renders the surrounding valid structure correctly (e.g. \frac{...}{...}, parentheses, etc.)
  • But it leaves the unrecognised command visible literally (e.g. showing \sinc as text) rather than failing the entire expression or producing a confusing partial error.
In practice, this makes it immediately obvious what needs fixing, without obscuring what’s already correct — which is especially helpful in teaching contexts and when iterating on math-heavy posts.
For example, rather than relying on \sinc being defined, the robust approach is to write it explicitly as an operator:
\frac{\Delta}{T}\operatorname{sinc}\!\left(\frac{\omega_r\Delta}{2}\right)
with:
\operatorname{sinc}(x)=\frac{\sin x}{x}
Overall this “render what you can, show the rest clearly” behaviour feels like a big usability win compared to older / less transparent failure modes. Thanks to everyone involved in the MathJax upgrade work.
I just want to warn everyone who came here via Google that this plugins is not available for the free tier of hosting plan. :expressionless_face:
Hi, I can understand your frustration. I’m sorry you feel that way. For future cases, you can take a look at the Plugins directory per plan here.
The math plugin is not listed on this page as a pro/business/enterprise plugin. So one may assume that is available for free plan. I am not suggesting that you should provide it for free. I just think it should be made a bit clearer.
Right. The page at Discourse pricing | Discourse - Civilized Discussion lists all plans and their limits, including plugins, where you can quickly see which plugins are allowed.
I see a new tool, RaTeX,
written in Rust, 100% compatible with Katex.
GitHub - erweixin/RaTeX: >99.5% KaTeX syntax coverage. LaTeX math renderer in pure Rust. No JavaScript, no WebView, no DOM. One Rust core → iOS, Android, Flutter, Web, PNG. C ABI · WASM · Server-side PNG/SVG. · GitHub
It might be a good substitute.
