Discourse Chat Integration
:information_source: Chat Integration is for using an external chat system together with Discourse — you may be looking for Discourse Chat which adds Chat functionality directly to Discourse.
:discourse2: Summary Discourse Chat Integration allows you to integrate your chat system of choice with Discourse.
:open_book: Install Guide This plugin is bundled with Discourse core. There is no need to install the plugin separately.
Features
discourse-chat-integration allows sending notifications about new Discourse posts to ‘group chats’ on a number of instant messaging platforms.
Notifications can be triggered by new topics, new replies, messages to a group, or mentions of a group. A notification in your instant messaging system will look something like this:
Configuration
  1. In your site settings, check chat_integration_enabled is :heavy_check_mark:
  2. Click on one of the providers below to see provider-specific setup instructions
  3. For more details, read ‘Configuring Rules’ below
Provider Notifications Slash Commands Post Transcripts Threaded Replies
Slack :white_check_mark: :white_check_mark: :white_check_mark: :white_check_mark:
Telegram :white_check_mark: :white_check_mark:
Discord :white_check_mark:
Mattermost :white_check_mark: :white_check_mark:
Google Chat :white_check_mark:
Matrix (element.io) :white_check_mark:
Zulip :white_check_mark:
Rocket.Chat :white_check_mark:
Gitter :white_check_mark:
Flowdock :white_check_mark:
Stride Docs
Microsoft Teams :white_check_mark:
Basecamp Docs
IRC Cloud Docs
Flock Docs
Webex :white_check_mark:
Terminology
There are three key concepts in discourse-chat-integration: Providers, Channels and Rules
Configuring Rules
In your forum’s admin panel, under Plugins, you should see a Chat Integrations section. Within that there will be tabs for each of your enabled providers:
Rules have a number of options which can be configured:
  • Type:
    • Normal - send notifications based on standard posts on the forum
    • Group Message - send notifications based on private messages which a specified group is a part of
    • Group Mention - send notifications whenever specified group is @mentioned in a standard post on the forum (mentions in private messages are ignored)
  • Filter:
    • All posts with threaded replies - notify for new posts matching this rule, create per-topic threads on the chat provider (not available in all integrations)
    • All posts and replies - notify for new posts matching this rule
    • First post only - notify only for new topics matching this rule
    • Tag added to topic - notify when a tag is added to a topic (the create post for category and tag changes site setting must be enabled for this to work)
    • Mute - prevent notifications matching this rule
  • Category (if type is ‘Normal’)
    • Match posts based on their category. Leave as “(all categories)” to match all posts on the forum
  • Group (if type is ‘Group Message’ or ‘Group Mention’)
    • Specify the group you want to receive notifications for
  • Tags
    • Enter a list of tags to match posts with at least one of the listed tags. Leave blank to match all posts
Multiple rules
When multiple rules match a post, the top-most rule in the user interface is executed. Rules are first sorted according to the criteria:
  1. Group mentions
  2. Group messages
  3. Normal
and then sorted within that by
  1. Mute
  2. All posts and replies
  3. First post only
For example, with the following rules
Filter Category Tags
All posts and replies Mentions of: @team (all tags)
Mute Support (all tags)
First post only Support unsupported-install
All posts and replies (all categories) (all tags)
Notifications would be triggered for
but not for
Security/Permissions
The site setting “chat integration discourse username” allows you to secure your notifications against leaking private information.
By default the system account is used, which means that there is no restriction on notifications sent. To secure your notifications you should create a non-staff user with appropriate access privileges, and enter its username in the site setting.
Slash Commands
If your provider supports slash commands, you can manage rules from within your chat interface. Each provider varies slightly in syntax, but in general they follow a similar structure. (Note that at this time, only the Slack integration implements threads.)
The commands available are
Posting a transcript
If your provider supports transcript posting, you can post your instant messaging history to discourse. This is currently only supported for the Slack provider. Note: You will need to be using the “Access Token” method of connecting to Slack.
Send /discourse post to see the interface. The plugin will try and “guess” where your current conversation starts, by looking for a gap in the message history of more than 3 minutes.
Alternatively, you can specify a number of posts after the command, or a URL to the first message.
To load a transcript for a Slack thread, you can use /discourse post thread {url}, where {url} is the permalink of the first message in the thread. For example:
/discourse post thread https://<slackname>.slack.com/archives/C6029G78F/p1522952993000017
Alternatively, you can use /discourse post with a thread-specific permalink like this:
/discourse post https://foo.slack.com/archives/G49KKS6AX/p1523062012000911?thread_ts=1523091738.000088&cid=G49KKS6AC
In both cases the “first/last message” UI is skipped - the entire thread is included in the transcript.
Adding new providers
Option 1: Submit a PR implementing your provider:
Option 2: Use your own plugin:
It is possible for third party plugins to register new “providers”. As an example, I’ve created a provider which sends webhooks to IFTTT. This could be used to automatically publish all posts in a category to facebook… or turn on your light when someone posts in Feature… or feed your fish whenever there’s a new Plugin.
CHANGELOG
TODO
It would be interesting to add support for Discourse’s own ActivityPub Plugin so that publishing could be triggered based on tags and other filters from chat integration.
Hello, last year Telegram announced forums/topics (mini chats within group chats). I tried to connect each individual mini chat to one or another category of my site. But as I understand, topic addresses are not supported by the plugin? For example, in my case, each topic has an address as follows: @telegram_topic /1, @telegram_topic /2, @telegram_topic /3
If I insert a standard chat name into the line, for example @telegram_chat, it works without problems.
It would be very convenient if the plugin had the ability to insert similar chat addresses (…/1), then users would not have to be subscribers to many independent channels tied to certain categories of the site.
Have you considered using tags to accomplish this?
:thinking: I think using tags is not entirely suitable for my case. Because even with the help of tags, I wouldn’t want all notifications to go into one channel, creating information noise. At the same time, instead of having 20 channels for 20 categories/tags, I would prefer to have one group chat where I could organize several mini-themed chats (by category/tag) where each user can view the one they need minichat and the ability to look into other minichat. I’m so bothered because in my region (Asia) most people use WhatsApp and Telegram chats - forums are not popular. But I’m trying to find a compromise).
Ps. If I repeat myself often, don’t judge me, I’m just trying to convey my thoughts correctly, as I use Google translator.
You should be able to filter which tags would apply to which chats, at least as far as I am understanding you.
It seems to me that we are talking about different things :thinking: I don’t have a question about filtering chats by tags/categories.
For context. Previously, Telegram had channels and chats (except for bots). These channels/chat rooms have a username, approximately @chat_username or @channel_username.
Since last year, Telegram has had the opportunity to turn chats into forums containing mini thematic chats like this. These mini chats have their own usernames, for example @chat_username /1, @chat_username /2. The convenience of such chats with minichat is that the user no longer needs to subscribe to several chats separate from each other, but just subscribe to one chat (for example, with the name of my site) and have access to many mini chats (in my case, each mini chat would target a specific category on the site) that are of interest to the user.
Now I want to connect these mini chats to this plugin, but it seems to me that the plugin does not support the mini chat username as chat_username /1.
Is there a way to create a rule where I can tag a new message and/or reply so it won’t post to target chat system (in this case Slack)?
Hey Albert, if we’re talking about normal Discourse tags, you can set up a ‘mute’ filter to prevent topics with that tag triggering notifications in Slack.
But in terms of individual posts, there is no way to filter them out.
I think I have the same want as you, Aizada:
I’d love to be able to have a Telegram group chat, with topics enabled (that somewhat correspond to the categories on Discourse), and then, in the Discourse/Chat integration settings, specify which topic it should post to.
I’ve tried to create a group chat with topics now (with just the bot and me), but when I type /help within a topic, the bot answers in the general chat.
Have you looked into this @david? I found this Stack Overflow thread, that shows how to get the message_thread_id (which is the topic id) and says that the bot API got support for this in 6.3.
Thanks for your work anyway! 🫶🏻
Hi @ErlendMS :wave:. We don’t have any enhancements for this plugin on our roadmap at the moment, but if someone would like to add ‘threading’ (aka topic) support for the telegram integration that would likely be pr-welcome.
We do have some threading support in the slack integration, so it should be possible to reuse some of that logic.
Is it possible to use this plugin to get notifications in Slack whenever a post is flagged for review? Thanks.
Does this plugin expose additional API functions?
Where do I request a PR review? I’ve submitted this PR late last week to add a new provider and it is still pending a reviewer. I’ve looked around different developer guides on meta and couldn’t find one for proper PR requests.
Here’s my PR: FEATURE: Added Power Automate as a new provider by benoitdesnoyers · Pull Request #204 · discourse/discourse-chat-integration · GitHub
Thanks,
Hello guys! we’ve just merged this pr for chat integration plugin
This change aims to remove the tags_changed option from the rule filtering from chat integration–we are doing this change because we are removing the Creation of a small action post when a topic's category or tags change setting.
But the functionality will remain the same, if you have discourse automation installed. The next time you run the migrations for this plugin, it will add a script to the discourse automation plugin that will run similarly to what we currently have.
This is an example of automation that will be created:
It will be sent to my channel based on the categories and watching tags that I have.
${ADDED_AND_REMOVED} is the default text; it will behave the same as the rule would.
We have also added for this script option a few options that can be used in the message:
  • ${TOPIC} for the topic name
  • ${REMOVED_TAGS} for the removed tags
  • ${ADDED_TAGS} for the added tags
    both removed and added will only trigger if they have a tag in them.
    For example: added: ${ADDED_TAGS} message will only trigger if there are added tags
We had an issue with the other PR(users who used other providers could not use the automation when topic tags changed), so to address it, we have made this new PR, where we account for every provider.
The Creation of a small action post when a topic's category or tags change setting will not appear in chat integration.
If you have discourse automation installed the next time you run the migrations for this plugin, it will add a script to the discourse automation plugin that will run similarly to what we currently have.
Your automations will look something like this:
And your providers are the enabled providers.
For example, I have Discord,Slack, Telegram and Google Chat enabled
Your channel name is the name you gave it in the chat integration settings.
For example, the name here is Spidey
We have a new batch of changes for the Automation/chat-integration
In this new batch, notable changes are:
  • We added Trigger with PMs, which lets you control whether this automation should be triggered even on private messages.
  • Solved an issue where Topic tags changed trigger automation was being triggered during topic creation.
As mentioned before – here
The create post for category and tag changes site setting currently can leak private tags/categories; one way that we found to keep that feature was by moving it to whispers:
It works similarly to small posts, but now, you need to have whisper allowed groups with some group to make it work.
I’ve merged a PR for core with this change and one for chat-integration, removing the usage of that setting; the automation feature added back should be 1:1 with the small action if anyone has any issue, please let us know!
I have some more updates to this plugin :steam_locomotive:
We have added trigger on field for Send Chat-Integration message automation.
What does it do?
It checks for when tags are:
  • Added and Removed (default)
  • Added
  • Removed
Currently, this check is inclusive.
A good example is if I set it to Added; For this automation to run, it is going to be necessary for any tag to be added to a topic.
When Tags added is set, the automation table looks like this:
Added tag to topic Removed Tag to topic Has automation ran?
:white_check_mark: :cross_mark: :white_check_mark:
:cross_mark: :white_check_mark: :cross_mark:
When Tags removed is set, the automation table looks like this:
Removed tag to topic Added Tag to topic Has automation ran?
Subject: Unable to access Plugins section for Chat Integration setup
Hello,
I’m an administrator of the LXDAO forum and I’m trying to set up the Discourse Chat Integration plugin to connect with Telegram. According to the official documentation, I should be able to configure this in the Plugins section of the admin panel.
However, in my admin dashboard, I only have access to four sections: General, Moderation, Security, and Reports. The Plugins section mentioned in the documentation does not appear to be available.
Could you please help me understand:
  1. Is the Chat Integration plugin already installed on our forum?
  2. Do I need additional permissions to access the Plugins section?
  3. If we’re using a hosted Discourse solution, are there any limitations regarding plugin installation/configuration?
As an administrator, what steps should I take to properly set up the Telegram integration for our community?
Thank you for your assistance!
