Allows you to associate geocoded locations with Topics and show them on a beautiful map. Also allows your users to record their location and collectively display them on a central users map on your site.
Please consider becoming an ongoing sponsor of my open source work at a level that suits your or your organisationâs resources and needs to ensure this plugin gets the maintenance it deserves and continues to work for your site in the future.
I do not provide any guaranteed support for free. I can provide support to businesses or institutions who sign up to one of my GOLD or PLATINUM monthly Sponsorship tiers.
There is an EARLY ACCESS version of Locations exposed exclusively to backers beyond a certain tier.
This version has the following features which the public version of Locations currently lacks:
Title
Description
Users-map globe
Adds an interactive 3D globe view for the Users Map, with avatars placed by location, drag/touch rotation, zoom, reset, search focus, user-card clicks, and always-on bump mapping.
Globe screen saver
Optional experimental idle screen saver showing a rotating 3D globe with user avatars below the header.
Enhanced users-map filters
Adds controls for result limit, search type, search term, and group filtering on the Users Map.
Nearby topic filter
Adds a nearby topic-list filter based on distance from the current userâs location.
IP-based user location lookup
Automatically estimates and stores user locations from IP data, with configurable trigger mode, granularity, cooldown, GeoNames resolution, skip-if-existing behavior, and debug logging.
If you would like these extra features, consider sponsoring me and making sure you go for a monthly tier which includes Early Access. Sponsoring me at the right tier will give you access to the Early Access version within 24 hours.
I am very new with this technology. I have installed the plugin (I see the Map command in the hamburger menu and I have a location field in my User profile page (with working georeference with nominatim) BUTâŚ
I donât see âAdd locationâ button in the editor.
This is my configuration:
And this is the editor window:
Finally, this is the way I have installed the plugin:
Just a heads up that this plugin will soon be moving to the same update schedule as the rest of Pavilionâs main plugins. This means that it will be brought in line with the latest Discourse core in the first week of every month. Details to follow specific to this plugin, but see further here:
Hi @angus confirmed the locations are now displaying on the user card but weâre still seeing the issue whereby some users have a map pin and map icon showing even if they donât have a location entered:
I cannot start the Discourse app because of the locations plugin currently. Attaching log below, it works if I comment out locations in app.yml. Can someone prioritize this and fix it?
Also, is there a way to only upgrade to tests-passed version of the plugin (if there is such a thing), like how the main discourse app does? So that we do not run into such issues in future.
Log
5: from /var/www/discourse/plugins/discourse-layouts/plugin.rb:49:in `block in activate!'
4: from /var/www/discourse/lib/discourse_event.rb:13:in `trigger'
3: from /usr/local/lib/ruby/2.6.0/set.rb:338:in `each'
2: from /usr/local/lib/ruby/2.6.0/set.rb:338:in `each_key'
1: from /var/www/discourse/lib/discourse_event.rb:14:in `block in trigger'
/var/www/discourse/plugins/discourse-locations/plugin.rb:234:in `block in activate!': uninitialized constant DiscourseLayouts::WidgetHelper
Did you mean? DiscourseLayouts::WidgetSerializer (NameError)
** INCOMPATIBLE PLUGIN **
You are unable to build Discourse due to errors in the plugin at
Please try removing this plugin and rebuilding again!
I, [2020-04-25T20:32:06.399307 #1] INFO -- : gem install icalendar -v 2.4.1 -i /var/www/discourse/plugins/discourse-events/gems/2.6.5 --no-document --ignore-dependencies --no-user-install
HEADS UP! iCalendar 2.0 is not backwards-compatible with 1.x. Please see the README for the new syntax
HEADS UP! icalendar 2.2.0 switches to non-strict parsing as default. Please see the README if you
rely on strict parsing for information on how to enable it.
ActiveSupport is required for TimeWithZone support, but not required for general use.
Successfully installed icalendar-2.4.1
1 gem installed
gem install geocoder -v 1.4.4 -i /var/www/discourse/plugins/discourse-locations/gems/2.6.5 --no-document --ignore-dependencies --no-user-install
Successfully installed geocoder-1.4.4
1 gem installed
I, [2020-04-25T20:32:06.400580 #1] INFO -- : Terminating async processes
I, [2020-04-25T20:32:06.400773 #1] INFO -- : Sending INT to HOME=/var/lib/postgresql USER=postgres exec chpst -u postgres:postgres:ssl-cert -U postgres:postgres:ssl-cert /usr/lib/postgresql/10/bin/postmaster -D /etc/postgresql/10/main pid: 50
I, [2020-04-25T20:32:06.400979 #1] INFO -- : Sending TERM to exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.conf pid: 167
167:signal-handler (1587846726) Received SIGTERM scheduling shutdown...
2020-04-25 20:32:06.401 UTC [50] LOG: received fast shutdown request
2020-04-25 20:32:06.403 UTC [50] LOG: aborting any active transactions
2020-04-25 20:32:06.406 UTC [50] LOG: worker process: logical replication launcher (PID 59) exited with exit code 1
167:M 25 Apr 2020 20:32:06.406 # User requested shutdown...
167:M 25 Apr 2020 20:32:06.406 * Saving the final RDB snapshot before exiting.
2020-04-25 20:32:06.409 UTC [54] LOG: shutting down
2020-04-25 20:32:06.439 UTC [50] LOG: database system is shut down
167:M 25 Apr 2020 20:32:06.502 * DB saved on disk
167:M 25 Apr 2020 20:32:06.502 # Redis is now ready to exit, bye bye...
FAILED
Pups::ExecError: cd /var/www/discourse && su discourse -c 'bundle exec rake db:migrate' failed with return #<Process::Status: pid 13098 exit 1>
exec failed with the params {"cd"=>"$home", "hook"=>"db_migrate", "cmd"=>["su discourse -c 'bundle exec rake db:migrate'"]}
b5a02d7f9df6b6a9dc160e269de30eef49bb0aeaf5dcb1b712bab5e6edad4030
root@discuss:/var/discourse#
Having a tests-passed branch in the plugin would unforatunately not help too much in this particuar situation, or a not-insignificant portion of other plugin incompatibility situations. People update at many different frequencies and have many different combinations of customisations.
That said, weâre starting to make some steps to address this problem. Weâre moving to a schedule of ensuring Pavilionâs primary open source plugins (this plugin, Events, Topic List Previews etc) are up to date with Discourse every 24 hours in the first 5 days of every month, starting May 1 to 5.
This gives you a safe window to update all the plugins on try.thepavilion.io along with Discourse itself with greater certainty that:
You wonât experience conflicts between the plugin and Discourse, and if you do they will be addressed within less than 24 hrs.
You wonât experience any issues due to changes in the plugin itself. Any potentially breaking changes to the plugin itself will happen outside this window.
Thanks, yeah, I was trying to figure out why my custom layout was not showing up either with the last update. It still doesnât seem to appear but I see on Pavilion that you are in the process to release updated doc for the changes in the plugin so I will wait a while.
The plugin was transferred from my personal github to Pavilionâs some time ago. When a repository is transferred, Github automatically redirects all links to the old location to the new one.
The first post will be changing a bit more in the coming weeks. Iâm going to write some documentation for this over on thepavilion.io and a shorter description here on meta.
