Forms for Discourse. This plugin lets you make rich and powerful forms for your Discourse forum. Better user onboarding, structured posting, data enrichment, automated actions and much more for your community.
Hello, @angus I have noticed that with the plugin installed and enabled it appears to shift the āMoreā button to the center instead of keeping it in the left. Any idea why this occurs? Thanks.
Hey @ppcole, yes it can. You would need to use the a āCreate Topicā action and the āPost Builderā for that. You can read further and follow up here:
This appears to have changed at the start of this year - brilliant!! No more sword of Damocles up there!
Iāve just started using the Custom Wizard Plugin again after a break; Iām impressed by just how refined and robust it is now - and how it can cater for many edge cases that arenāt covered by core or the official plugin / TC ecosystem. Or indeed, it can refine and join up some of them quite effectively.
My latest little project where it has been super helpful has been overcoming the challenging UI for Discourse Calendar (and Event), which is admin-friendly rather than user-friendly.
Iām trying to get the subscription information to look into upgrading, but every reference to the pricing page is a broken link - https://custom-wizard.pavilion.tech/pricing/
I guess my next question isā¦how to set this up? Thereās not documentation that I can find on the Pavilion website, unless Iām missing something - Discourse Custom Wizard - Pavilion
custom_wizard_enabled: Disable this to prevent custom wizards from being used.
wizard_redirect_exclude_paths: Paths that cannot be redirected to from a wizard.
wizard_recognised_image_upload_formats: Upload types that will treated as images.
wizard_apis_enabled: Enable wizard API features. This is experimental and has not been thoroughly tested. Use with caution.
Assuming though that itās just enabled by default now, Iām not quite sure how to go about setting it up, because the Select an API dropdown and the Select an endpoint dropdown are both blank and Iām not sure what the steps are to populate those dropdowns.
After updating Discourse to the latest v2026.3.0-latest.1 (fb8ef7ee72) the /admin/wizards and /w pathes arenāt accessible anymore while /admin/plugins/discourse-custom-wizard/settings is working fine
Please bear in mind that this option will not be available for much longer. As soon as custom-wizard is fixed, I recommend you switch back to to the new compiler.
