כרטיס משתמש "נראה לאחרונה"
This theme component will allow you to include the “last seen” user statistic in user profile cards.
Repo: GitHub - tshenry/discourse-last-seen-user-card-theme-component
Before
After
About
In addition to my own interest in having this stat added to user cards, there’s been some discussion on here that inspired this theme component’s creation:
Installation
Follow this guide here:
Please feel free to post if there are any questions, problems, or suggestions!
45 לייקים
This is fantastic. I will use this function a lot as I assess new members’ engagement and chase particular people down who I work with closely.
2 לייקים
This has had a minor update:
  • Reduced the amount of code by switching from a full template override to using the existing plugin outlet to achieve the same positioning.
For anyone that uses this or is interested in using it, there are four metadata positions on the user card. Currently, starting from the left it goes last post, date joined, last seen, and time read. Which position would you prefer the "last seen" metadata to be displayed?
  • First
  • Second
  • Third (where it is currently)
  • Fourth
0 voters
I imagine it’s not extremely important to most, but I’m curious if there is a preference that I can consider for a future update.
4 לייקים
I don’t mind where it is so long as it is there.
לייק 1
I’ve update this to position “Last Seen” first in the list. Thanks to all that voiced their opinion :grin:
8 לייקים
@tshenry Is it compatible with latest Discourse? It’s not working although installed.
I just checked and it’s working on the latest tests-passed. Did you make sure to refresh the page after adding the component to your main theme?
3 לייקים
Did you check on mobile view as well?
לייק 1
Ah, good point! Fun fact - this component was created before mobile user cards existed! Because of that, it was only set up to work on desktop.
I’ve just pushed an update that should support both environments:
8 לייקים
I’ve got the update, thanks.
2 לייקים
Reviving this one: Just to confirm that it still works like a charm and is super useful!
This makes it super quick easy to check if the user is in fact still an active member. Before I always had to open full profile to decide if it’s worth the time so send a private message to the user.
Would love to see that in core!
4 לייקים
Yes!! Should definitely be in core IMO. Until then thanks very much to @tshenry!
3 לייקים
I noticed since my last Discourse update that the Last Seen text in the user card is much bigger than the rest and also bold. I checked and it is wrapped in <h3> so I undid this by putting
#user-card .last-seen-metadata h3 {
    font-size: unset;
    font-weight: unset;
in the theme css.
No idea if this is an intended effect, so I wanted to share my experience.
2 לייקים
Probably not.
4 לייקים
I’ve added a pull request for the component here to remove the heading tag to match the Discourse change:
8 לייקים
Thank you very much for explanation and also for the PR! :slight_smile:
2 לייקים
Thanks very much for this fix! Will it make it into the 3.3.x stable branch?
Theme component updates are completely separate from core updates, you can update them at any time from the admin UI regardless of the core updates.
2 לייקים
Oops, sorry, I forgot that this is a theme component and not part of core.
2 לייקים
Works great, but for some reason it’s showing last in the list (after cheers) for me.
לייק 1
