Discourse has the ability for themes to have “settings” that can be added by theme developers to allow site owners to customize themes through UI without having to change any line of code and worry about losing their changes with future updates for the theme.
Themes can also alter certain themeable site settings, for more information on that, see the Themeable site settings topic.
Adding settings to your theme
Adding settings to your theme is a bit different from adding CSS and JS code, that is there is no way to do it via the UI.
The way to add settings is to create a repository for your theme, and in the root folder of your repository create a new settings.yaml (or settings.yml) file. In this file you’ll use the YAML language to define your theme settings.
Note: You may find it helpful to make use of the Theme CLI, which tremendously simplifies the development process.
Now if you’re familiar with plugin development, this shouldn’t be a new thing to you - it mostly works the same way as adding site settings to your plugin. Just dump some valid YAML in your settings file and you’ll be good to go.
A valid theme setting must have a name and default value, that’s the bare minimum and it looks like this:
simple_setting: true
As you can probably tell, that will create a setting with the name simple_setting and it’ll have true as its default value.
Similarly, you can add something like this:
site_name: My Forums
max_avatars: 7
And you’ll have two more settings, site_name which will be a string setting with “My Forums” as the default value, and max_avatars as an integer setting with default value of 7.
You can access your settings in your JS code like this: settings.your_setting_key.
So until this point we’ve covered the simplest way to define settings. In the next section we’ll dive a bit deeper into the various types of settings and how you can use them.
Supported types
There are 8 types of settings:
integerfloatstringbool(for boolean)listenumobjects(replacement forjson_schema)upload(for images)
And you can specify type by adding a type attribute to your setting like this:
float_setting:
type: float
default: 3.14
I should say that you don’t always have to explicitly set a type attribute because Discourse is smart enough to work out the setting type from the setting’s default value. So you can reduce the above example to this:
float_setting:
default: 3.14
That said, you need to set a type attribute when working with list and enum settings, otherwise Discourse will not recognize them correctly.
List Setting:
whitelisted_fruits:
default: apples|oranges
type: list
Enum Setting:
favorite_fruit:
default: orange
type: enum
choices:
- apple
- banana
In case the difference between list and enum settings is not clear to you: enum settings allow your theme users to select only one value from a set of values defined by you (see the choices attribute).
On the other hand, list settings allow your users to create their own list (i.e. an array) of values. They can add to or remove from the setting’s default list of values.
You can set the default list of values for the setting by joining the values with a vertical bar | character. See the list setting in the example above.
You can see a real-world use case for list settings here: Auto-Linkify Words.
Note: Pay attention to indentation when working with YAML because YAML is very picky about spaces and will throw a syntax error if your code indentation is incorrect.
objects type
The objects setting type is a special type that allows you to accomplish advanced settings with custom structure and validations. We have a separate documentation for this type.
Setting description and localizations
You can add description text to your theme setting and it’ll be shown as a label directly under the setting. To do that simply add a description attribute to your setting like so:
whitelisted_fruits:
type: list
description: "This text will be displayed under this setting and it explains what the setting does!"
And you’ll get this:
Multiple languages support
If you know more than one language, and you’d like to add support for those languages to your theme, then you can totally do that provided that Discourse supports said languages.
First of all, make sure the language you want to support is in this list:
Languages list
| Code | Name | |||
| ar | اللغة العربية | |||
| bs_BA | bosanski jezik | |||
| ca | català | |||
| cs | čeština | |||
| da | dansk | |||
| de | Deutsch | |||
| el | ελληνικά | |||
| en | English | |||
| es | Español | |||
| et | eesti | |||
| fa_IR | فارسی | |||
| fi | suomi | |||
| fr | Français | |||
| gl | galego | |||
| he | עברית | |||
| id | Indonesian | |||
| it | Italiano | |||
| ja | 日本語 | |||
| ko | 한국어 | |||
| lv | latviešu valoda | |||
| nb_NO | Norsk bokmål | |||
| nl | Nederlands | |||
| pl_PL | język polski | |||
| pt | Português | |||
| pt_BR | Português (BR) | |||
| ro | limba română | |||
| ru | Русский | |||
| sk | slovenčina | |||
| sq | Shqip | |||
| sr | српски језик | |||
| sv | svenska | |||
| te | తెలుగు | |||
| th | ไทย | |||
| tr_TR | Türkçe | |||
| uk | українська мова | |||
| ur | اردو | |||
| vi | Việt Nam | |||
| zh_CN | 中文 | |||
| zh_TW | 中文 (TW) |
(If you can’t see your language in the list then you might want to take a look at How to add a new language)
Then you’ll need find your language code from the above list and use the language code as a key under the description attribute and translation as a value for the key like so:
whitelisted_fruits:
type: list
description:
en: English text
ar: نص باللغة العربية
fr: Texte français
And now you have support for 3 languages: English, Arabic and French.
Min and max attributes
Sometimes you may need to specify limits that a setting value can’t exceed to prevent your users from accidentally breaking the theme or possibly the whole site.
To specify limits, simply add a min or max or both attributes to your setting like so:
integer_setting:
default: 10
min: 5
max: 100
You can specify limits to integer, float and string type settings. For integer and float settings, the value of the setting itself is checked against the limits. And for string settings, the length of the value is checked against the specified limits.
If your user tries to enter a value that’s not within the allowed range, they’ll see an error telling them what the min and max values are.
Access to settings in your JS/CSS/Handlebars
Theme settings are made available globally as a settings variable in theme JavaScript files. For example:
// {theme}/javascripts/discourse/api-initializers/init-theme.gjs
export default apiInitializer((api) => {
console.log("settings are", settings);
This settings object is also usable as normal within .gjs <template> tags.
In CSS, you’ll get a variable created for every setting of your theme and each variable will have the same name as the setting it represents.
So if you had a float setting called global_font_size and a string setting called site_background, you could do something like this in your theme CSS:
html {
font-size: #{$global-font-size}px;
background: $site-background;
Related Topics
This document is version controlled - suggest changes on github.
