自定义头部链接
:discourse2: Summary Custom Header Links allows you to easily add custom text-based links to the header.
:eyeglasses: Preview Preview on Discourse Theme Creator
:hammer_and_wrench: Repository Link https://github.com/discourse/discourse-custom-header-links
:open_book: New to Discourse Themes? Beginner’s guide to using Discourse Themes
Install this theme component
Features
Desktop
Mobile
(due to very limited space I don’t recommend adding more than one link on mobiles)
Settings
Name Description
custom header links Custom links to be displayed in the header
links position Note that when links are displayed on the left, they’re automatically hidden while scrolling within topics to make room for the title
Adding links is straightforward. Every link needs 6 items. You enter comma delimited values in this order:
link text, link title, URL, view, target, hide on scroll
Link text: the text for the link.
Link title: the text that shows when the link is hovered.
URL: The path for the link (can be relative).
View: vdm = desktop and mobile, vdo = desktop only, vmo = mobile only.
Target: blank = opens in a new tab, self = opens in the same tab.
Hide on scroll: remove = hides the link when the title is expanded on topic pages keep = keeps the link visible even when the title is visible on topic pages.
If you’re not sure what hide on scroll does, here’s an example:
Most Liked and Privacy are set to keep and so they remain visible. The other links are set to remove, and so are hidden when the title expands in the header. This only affects topic pages.
Links position: This setting allows you to change the default layout so links will appear on the left near the logo instead of on the right. Note that when positioned to the left, links will automatically be hidden when scrolling within topics to make room for the topic title.
:discourse2: Hosted by us? Theme components are available to use on our Standard, Business, and Enterprise plans.
82 个赞
How can I add custom hamburger menu
Header Submenus
Structuring a multilingual community
Control CSS based on user's logged in state
Display StatusPage status on as a header link
Custom Header Links (icons)
Looking for a freelancer to implement a custom Discourse theme (based on an existing mockup)
Add a global header between Discourse & Website
How to make custom setting type
Is it possible to have users' job titles next to their names on posts?
Link to find all deleted posts by all users in a particular period
Dropdown links in existing Header
Insert Link to External Website
Is anyone here using their Discourse instance as their entire website?
How to fire on every footer load (or page load?)
Custom links above header bar
Pre seeded posts all missing - Missing Terms of Service, FAQ and Privacy pages
Dropdown header links in the existing Header
Add a "curated personal learning" page for users
Redirect search icon to search page
Possible to change main logo URL?
2021: The Year in Review
How to add breadcrumb?
How to add contact us page?
Navigation bar above all post
Adding link to blog on main page
Customizing your site with existing theme components
Show "new topic" when not logged in
How can I add a new button to the topbar?
⬇️ Dropdown Header
How to fix logo size?
Links into the header block
Customize the header with links, icons, or menus
Privacy Policy does't meet Google's requirements
Customize Your Site Branding
Nextcloud support
How to override the site-header.hbs file from custom theme?
Sidebar link / top button to PM admin
Toolbar under site header per category
Link buttons on the top disappear when scrolling around the site
Disclaimer section on the "about" page
What Themes are being used for these Discourse forums?
Add button in header for logged in users
Use decorateWidget to add text link to header
[PAID] Expert Wanted for Forum Redesign
Add social media handles on home page
Create hyperlink from home logo
Configure a custom sidebar link to open in a new tab
2023: The Year in Review
Modifying Header
Fully Theme
Visiting /admin/upgrade may lead to a server error
How do I go about making a very customized theme?
How to Integrate a Custom Plugin in discourse UI
Embedding a whole Discourse forum on another site in an <iframe>
Memberstack + Webflow + Discourse OpenID Connect
Custom website header with forum
Brave default Theme
Why does the logo navigate to Discourse home not main site home
How to make sidebar sticky?
Forum navbar is repeating
Best place(s) to link back to a non-forum homepage?
Adding a header link for Guests Only
Adding my Nav into the header bar
Link on Top header to Go to Home page of main site
How to finely scroll out custom header?
Can I add a icon and link back to my homesite at the top bar
Header Submenus
Custom Header links was automatically hide when scrolling topic page contents
Link behavior inconsistent
Upcoming Header Changes - Preparing Themes and Plugins
How to add a "button" which composes a pre-filled topic
Where to place project external URL?
Change destination of logo link
External header links are not opening in a new tab
How to split the forum into two main parts (general/groups) and how to display only subcategories I can create a new post in?
Add secondary url / embed into Wordpress
"An empty string is not a valid JSON string" when updating theme component #2
How can I add a button to the header?
Showing categories statically above most recent posts
How to add a button to the header area?
don’t know if this has been suggested, tried reading back but couldn’t find it.
was thinking that maybe adding the ability to create “sub-links” thus creating the idea of a list that you could edit (text color, background hover etc.) to get results similar to what zoom has
8 个赞
the links that have the arrow to the right like developer means that it has “sub-links”
1 个赞
Is it possible to add some basic dropdown menu to an any item?
I couldn’t create a dropdown menu with “Custom header links”. It seems Zoom did that. I reviewed their dropdown menu via console, but I couldn’t figure out how they interfere with the html of this component for adding dropdown to any item.
Is there a way to add this dropdown to item? @Johani
<div id="dropdown">
  <a title="Zoom Developer Documentation" href="https://marketplace.zoom.us/docs" target="_blank">Developer</a>
  <span class="caret"></span>
  <div class="dropdown-content">
    <a title="Zoom API Docs" href="https://marketplace.zoom.us/docs/api-reference/introduction" target="_blank">API</a>
    <a title="Zoom SDK Docs" href="https://marketplace.zoom.us/docs/sdk/native-sdks/introduction" target="_blank">SDK</a>
    <a title="Zoom Developer Blog" href="https://medium.com/zoom-developer-blog" target="_blank">Blog</a>
    <a title="Zoom Developer Changelog" href="https://marketplace.zoom.us/docs/changelog" target="_blank">Changelog</a>
    <a title="Zoom Developer Survey" href="https://docs.google.com/forms/d/e/1FAIpQLSeJPLhNuxjtkxyyV276R8S_nYz99fpMbbS8VWkC8Hwi7-2Byg/viewform" target="_blank">Survey</a>
  </div>
</div>
5 个赞
Has anyone run into any issues with links not opening when setting links position to “left”?
Links work on Preview but not when I apply it to a theme.
Right alined links work fine though.
1 个赞
Hi! Thanks for creating this.
Is it possible to add an SVG before the text link? If so - how?
1 个赞
Have you found a solution for this? I am look for the same solution.
6 个赞
how can the title convert **formatting code** into actual formatting? also how about Font Awesome icons before the text?
2 个赞
Could be possible to add a flag to show or hide links as specific groups of users?
3 个赞
Is there a way this theme component can allow for dropdown navigation? That means, when I hover over a header link, it has sub-items that appear underneath it. I know that this can be done via html/css as shown here:
2 个赞
Thank you for creating this component!
One question and potentially a feature request: can we show a specific link for a specific group?
For example, if a user is in group customers I’d like to show a link to the customer’s control panel, if a user is in group workers I’d like to add a link to a different panel.
I think this would be a very useful feature.
The group name could be the last (optional) parameter.
2 个赞
太好了!我刚找到这个,之前试了很多其他的横幅和组件。这正是我需要的!
一个请求/建议:能够重新排序链接。我刚创建了一堆,意识到我想在顶部添加一个。现在我不得不手动复制粘贴所有内容,这实际上非常麻烦,因为我在向下复制时它们会不断同步/更新其他条目。
拖放或上下按钮对未来的用户(或未来的编辑)将非常有用。
4 个赞
由于我们使用了 flex 属性,您已经可以通过几行 CSS 代码轻松地操作顺序。
例如:
  • 默认顺序
  • 自定义顺序
CSS 示例:
.custom-header-links li {
  &:nth-child(1) {
    order: 3;
    background: red;
  &:nth-child(2) {
    order: 1;
    background: green;
  &:nth-child(3) {
    order: 2;
    background: yellow;
5 个赞
@Nick_Chomey 我经常发现自己需要这样做,不仅是为了这个主题组件,还包括许多使用 type: list 设置的其他主题组件。我之前曾计划提交一个功能请求,但我完全忘记了,但既然你提醒了我,我已经在这里添加了一个:
3 个赞
@dax 谢谢!我竟然不知道这是可能的!
@keegan 看起来很棒,希望将来能被添加!
2 个赞
我也正在寻找同样的解决方案,您是否已经弄清楚他们是如何做到的了?
谢谢!
1 个赞
您好 @Johani
感谢您创建如此出色的组件!
是否可以仅在用户登录时显示链接?
这将是一个外部链接。
1 个赞
@andreas_can 欢迎来到 Meta :wave:
此组件会根据链接文本为每个链接添加一个 CSS 类。添加的类与您为链接提供的文本相同,只是空格被替换为连字符(-),并且文本设置为小写。然后,在末尾附加字符串 -custom-header-links
因此,如果您添加一个文本为
privacy
的链接,那么链接元素将具有类
privacy-custom-header-links
如果您的链接文本是
Visit Shop
那么 CSS 类将是
visit-shop-custom-header-links
所以,现在您知道了添加到每个链接的类。回到您的问题。
当用户未登录时,Discourse 会向 <HTML> 标签添加一个 CSS 类。该类是
anon
因此,您可以使用它来隐藏某些链接,使其不对未登录用户显示。假设我有一个文本为
Customer Support
的链接,并且我不想让未登录用户看到它。
然后,我将在主主题的 common > CSS 选项卡中添加此 CSS
.anon {
  .customer-support-custom-header-links {
    display: none;
这将隐藏未登录用户的特定链接。
11 个赞
非常感谢您如此快速而详尽的回复!
这正是我想要的。
我会试试看 :slightly_smiling_face:
3 个赞
请注意,CSS display: none; 仅从浏览器渲染中隐藏链接,但对于查看页面源代码、网络爬虫和搜索引擎的用户来说,它始终是完全可见的。
3 个赞
