frold requests a visual indicator to easily identify the original topic starter in long threads. Mittineague suggests using CSS to modify the post avatar, and codinghorror confirms that the necessary CSS selector exists. mcwumbly shares a relevant theme component created by a community member.
Browsing a long thread - you sometimes forget who was the original topic starter - especially if you return to the topic days after last time you read it and jump into the discussion…
Therefore I request a solution that let you easily see who was the original Thread starter or topic starter…
Eg a icon or something that visualize who did original start this topic…
Might the post avatar already have a class attribute value indicating its a post made by the topic starter? If so a simple CSS declaration with the right selector could do something like add a border radius. It might be more trouble if the change took up too many more pixels of screen real estate. I think that anything that didn’t exceed what the flairs do should be OK.
What does the HTML for a post avatar of the OP look like in your dev tools inspect?
