Discourse Calendar (and Event)
:discourse2: Summary Discourse Calendar and Event adds dynamic and interactive calendar and event features to your Discourse site.
:open_book: Install Guide This plugin is bundled with Discourse core. There is no need to install the plugin separately.
Enabling Calendar (and Event)
The Calendar plugin can be enabled either by the toggle or from its settings, both accessible from your admin/plugins page:
/admin/plugins
Features
Somewhat unsurprisingly, Discourse Calendar (and Event) adds both the calendar and event features to your Discourse site. With these, you can create individual topic calendars to track important occasions or timelines, display calendars in categories, add a holiday calendar to mark vacations, absences, or sick days, create interactive event topics, as well as show an easy-access calendar summary of all of your upcoming events.
Calendars
Bespoke calendars can be created in multiple topics, and ones you wish to give higher visibility to can be displayed above a category’s topic list.
You can find more detailed information on how to create and use calendars in:
Events
The Event feature allows interactive elements to be inserted into topics which your members can use to sign up to attend or participate in your community’s activities. These are all summarised in a dedicated site-wide calendar, with the option to add an easy-access link to your navigation menu. You can find more information on how to create and use this feature in:
:exclamation: This should not be confused with Pavilion’s Events plugin (note the plural)
Calendar Settings
Name Description
calendar enabled Enable the discourse-calendar plugin. This will add support for a [calendar][/calendar] tag in the first post of a topic.
holiday calendar topic id Topic ID of staffs holiday / absence calendar.
holiday status emoji Defines the emoji used for the holiday status.
delete expired event posts after Posts with expired events will be automatically deleted after (n) hours. Set to -1 to disable deletion.
all day event start time Events that do not have a start time specified will start at this time. Format is HH:mm. For 6:00 am, enter 06:00
all day event end time Events that do not have a end time specified will end at this time. Format is HH:mm. For 6:00 pm, enter 18:00
calendar categories Display a calendar at the top of a category. Mandatory settings are categoryId and postId. eg: categoryId=6;postId=453[1] Other valid settings: tzPicker[2], weekends[3] and defaultView[4].
calendar categories outlet Allows to change which outlet should show the category calendar.
working days Set working days. You can display the availability of a group using the timezones tag in a post, eg: [timezones group=admins][timezones]
working day start hour Start time of the working day hours.
working day end hour End time of the working day hours.
close to working day hours extension Set extension time in working day hours to highlight the timezones.
calendar automatic holidays enabled Automatically set holiday status based on a users region (note: you can disable specific automatic holidays in plugin settings)
map events title Maps title of the sidebar calendar based on category. Defaults to “Upcoming events”
Event Settings
Name Description
discourse post event enabled Enables the Event features. Note: also needs calendar enabled to be enabled.
discourse post event allowed on groups Groups that are allowed to create events.
displayed invitees limit Limits the numbers of invitees displayed on an event.
display post event date on topic title Displays the date of the event after the topic title.
use local event date Use local date after topic title instead of relative time.
discourse post event edit notifications time extension Extends (in minutes) the period after the end of an event when going invitees are still being notified from edit in the original post.
discourse post event allowed custom fields Allows to let each event to set the value of custom fields.
events calendar categories Display an events calendar at the top of a category.
sort categories by event start date enabled Enable the sorting of category topics by event start date.
disable resorting on categories enabled Allow categories to disable the ability for users to sort on the event category.
sidebar show upcoming events Show upcoming events link in the sidebar under ‘More’. Requires post event enabled
map events to color Assigns an event color to a specified tag or category
:information_source: :curling_stone: The discourse-post-event/events.json endpoint now has an added parameter to switch between simple and detailed response. To get the detailed response you can add ?include_details=true:
/discourse-post-event/events.json?include_details=true
Integrations with Other Plugins
You can use a component from this plugin with Right Sidebar Blocks. You’ll want to ensure the desired route is enabled in the Right Sidebar Blocks component. The block name will be upcoming-events-list. Historically, there were additional settings required in the Calendar plugin itself, but this has been streamlined.
This is how the sidebar calendar will appear by default.
If you don’t want the time, you can add an empty timeFormat value in the component’s block setting.
:discourse2: Hosted by us? This plugin is available on our Business and Enterprise tiers Calendar | Discourse - Civilized Discussion
  1. categoryId is the category the calendar will be displayed on top of.
    postId is the post in which you put the calendar in with [calendar][/calendar] ↩
  2. it can display a time zone picker on the upper right of the calendar. False by default, you can enable it with tzPicker=true ↩
  3. it can hide Saturdays and Sundays from the calendar. True by default. You can set it to false with weekends=false. ↩
  4. defaultView will set the calendar’s view (day, week, etc;). It can be set as:
    defaultView=agendaDay
    defaultView=agendaWeek
    defaultView=month (default)
    defaultView=listNextYear ↩
How to use the calendar plugin?
Events Plugin :calendar:
Discourse Calendar - How to?
Calendar plugin, nothing is displayed
Discourse 2.2.0.beta3 Release Notes
Discourse Calendar dislpay link text rather than link url
Ability to mark any post as unread
Is there a room booking plugin?
📅 Event List Widget (Layouts Plugin)
I am looking for a webhook or event api
Inserting date/time into new topic's title field (ie, right here > !)
Db:migrate fails on discourse-calendar
Creating sub-communities in a discourse server
Plugin to show upcoming events on hosted discourse
Please better document the Discourse Calendar plugin
Go from a Wordpress + Discourse structure to a Discourse site only?
Vacation autoresponder for users who are away?
Plugin to gather approvals / signatures on an initiative?
Moderator/Admin Off Duty Button
Use Case Question - Room/Equipment Booking
Best practices for communicating to user base
Integrate with Discourse-calendar
My Wiki of useful Meta (and other) links
Quotes in event name clears attendees
Calendar in Discourse
Show Cakeday dates on the Calendar plugin
Agenda de colegio
Display a category as a calendar by scheduled Topic-timer dates
Why you should use Discourse internally for your company/team instead of Slack (4 years use case)
SEO applied to Discourse Official Plugins
Help us test Horizon, our newest theme
When "closing" event it moves it to today's date & time
How to display different calendar views?
Discourse calendar and event iCal integration?
Can the auto-responder fire on @mentions?
Event/Calendar Plugin - Cannot select a user for bulk-invite
Bulk Invite via modal only allowing one user (and not displaying correctly)
Event Creation
500 Error when posting, moment.tz runtime error
Best practice for a topic for a recurring event
How to get "back" btn
Event Chat Channels Now Available
📅 New Calendar Feature: End Date for Recurring Events
🌍 New Calendar Feature: Show Local Time
What livestream/webinar platforms do you use?
Custom Wizard Plugin :mage:
ICS → Discourse Importer
How have you built a local community around Discourse?
What happens next?
Bundling more popular plugins with Discourse core
Category Calendar with defaultView="listNextYear" not showing events
Calendar Core - Needs any special theme?
Creating and managing calendars
Sorting Categories by Title
Creating and managing events
The "Save Changes" button is very low on my user preferences interface page
Group Timezones
Available hours / work hours flair
Feature request: wrap calendar items when there's just one per day
Custom Discourse instance for a writers club
Unread messages blue numbers appearing in Latest lately (when they shouldn't)?
Database migration chokes on huge value of a "calendar-details" item in table "post_custom_fields"
"Out of office" user indicator
Calendar plugin features to make it really useful for us
Topic List Previews (TLP)
Can discourse display topic replies in reverse order?
Discourse Livestream
New to Discourse, have some questions :)
Expired events with end times are being removed from upcoming-events even with setting set to -1
Setup Continuous Integration using GitHub Actions
Add color to events based on event category or tag?
Is there any way to change the starting date of the Calendar?
Add recurrent items within a date-range
This plugin is promising - but there’s some features that are missing that prevents us from jumping from Pavilion’s plugin
  • Display non-all-day events with the start time on the calendar, currently every event looks like an all day event.
  • ‘Add Event’ button in the composer next to the tag selector (not hidden in the cog)
  • Limit which categories can have events, and if a events are compulsory in a category
Nice to haves:
  • Event meta data in the topic only appears/is entered at the top of the topic (instead of where ever the curser is
  • ability to limit which groups can make events in a category (for example - only ‘EventPlanners’ group can create events in the ‘Discussion’ category, but all users can create non-event topics (or edit topics if the topic is set to Wiki)
  • change URL of /upcoming-events to /calendar
2 posts were split to a new topic: Holiday status being incorrectly applied
Hello there,
Thank you for this work.
I have 2 UX questions:
  • Is it possible to display “Add event” button next to “Add location” button in topic editor ? Like it was the case with pavillion plugin ?
  • Is there a possibility to add Calendar top menu entry ? I don’t find it in settings
This looks great! Some thoughts/questions:
Am I correct in assuming that to create a calendar you simply create a new thread/topic, and paste the following into it:
Name Of Calendar
[calendar]
[/calendar]
Then to add entries to the calendar you simply make a new post in the sam thread with something like the following (by clicking on the insert time/date icon in the post options):
Name of Event/Entry
[date-range from=2024-04-18 to=2024-04-19 timezone="Europe/London"]
This adds the entry to the calendar which is great, however:
  • Is there any way to add entries to a calendar but let those entires have a dedicated thread/topic as well? (I see you can add events in new threads, but there doesn’t appear to be any way to add those events to a calendar).
  • Is there any way to feature ‘Upcoming Events’ from a specific calendar in the digest emails? Or maybe the left hand column, and with each entry linking to the dedicated thread for that entry?
If this is not currently possible do you have any plans to add it?
@vinothkannans Could you help me review this pr?
Are there plans to add a URL feed that users can subscribe to? I’m sure it would be tricky for all events vs the ones they have RSVP’d to.
Secondly, an additional layer would be amazing if it could recognize private events (or maybe that’s just a different URL feed per group).
There is no rss feed for the /upcoming-events url though—that would be a nice addition!
What about caldav sync ?
That would also for me be a reason to switch, indeed.
This needs more updating as it mentions a. Event Insert in composer and adding event details not as pictured. Unless Event was an add on?
I’ve installed the plug-in and the calendar tag works in the first post of a topic. But I don’t see any event or calendar options in the gear menu:
Can someone please explain what I need to do to get the event option in the gear menu?
You need to enable the Event portion of the plugin discourse post event enabled
Thanks. I somehow missed this setting.
How do you get create event to show in a Category topic with replies being events?
I see the create event works on creating new topics. But looking to have a Calender in a topic with replies adding events. It works partially with insert date but not as good as create event has more options.
Currently users can set the region in their profile preferences.
grafik
I’d like to let them set their region during signup by showing this field in the registration form. Is that feasible?
Will a deleted reply still appear on the calendar?
I can’t find any setting for changing first day of week to monday, is this trivial to implement if missing? :thinking:
Another issue is that that time & date entry is broken, if it’s an all day event there should be an option to select it before the time entry fields mess up the dates, and the dates seem to change randomly when editing.
Also noticed that it’s possible to enter 00:00 in both time & date, (which sometimes works, sometimes doesn’t) leading to calendar giving an error which will then cause some conflict with drafts leading to a repeated 422 error until the page is rolled back to an earlier revision, then re-edited etc.
Please refer here
There isn’t such setting and that’s why I don’t use it. And I bet the team would fix that error if it would be trivial trick.
