A code metric gem may help: rails_best_practices
(Erick Guan) #1
rails_best_practices is a gem can be used to check the code quality by complain about code patterns.
It can complain a lot of things. We can also add additional check.
Last time, it complains about 200 more warnings. Most are trivial things. Anyway, hope it helps.
(Jeff Atwood) #2
Perhaps if you could run it and filter to just the stuff you feel would be helpful for us?
