About administration for begginer , Clean Cloud
(Tumi) #1
Hello
Some questions. I got clean server just ubuntu. Now after installation i dont know:
  • should i install any “software” like iptables (firewall) or somethink else? Or docker over this ?
  • should i know/learn hot to configure somethink more on server?
  • should i connecting via ssh as non admin ? how to do it ? just create an new user only ?
for example - after install a docker - "If you would like to use Docker as a non-root user, you should now consider
adding your user to the “docker” group with something like:
sudo usermod -aG docker" Should i do it ?
#2
Follow this guide https://github.com/discourse/discourse/blob/master/docs/INSTALL-cloud.md
This is the one I use all the time.
A-Z steps are included there.
(Tumi) #3
Man i know it. Im asking about somethink more . like install docker and discourse as non-root user…
(Joshua Rosenfeld) #4
You need root access to install Discourse.
(Tumi) #5
Btw i have got warning… Discourse requires 1GB RAM to run. This system does not appear
to have sufficient memory. I have got 1gb ram cloud so what hmn ??
