Activation E-Mail Problem
(Serhat Kapusuz) #1
i did everything. i cant take activation email. what is wrong ?
#2
Try to send email with for example PHP using those same details. Possible problems can be, SMTP is not activated for that API key, port 587 is blocked, etc
(Serhat Kapusuz) #3
Yes u are right Problem is sparkpost API…
Leaving the field blank will allow access by valid API keys from any IP address.
UPDATE API KEY
i uptade ip section. after this i found solution. thank you.
