Ad blocker blocks ad plugin in admin. Disable ad blockers to fix
(Jeff Vienneau) #1
Just installed the advertising plugin and it does not seem to be working.
I am getting this when I navigate to admin plugins for house ads:
Network Error
while trying to load /admin/plugins/adplugin/house_ads.json
Please check your connection.
Basically, I added it to the app.yml and did the git pull & rebuild app step.
Am I missing something?
(Rafael dos Santos Silva) #2
Are you using any type of ad block extension?
(Jeff Vienneau) #3
I am but… would that block even the admin settings?
(Rafael dos Santos Silva) #4
As you just found out, they will.
(Jeff Vienneau) #5
Thanks. I’ll check after this rebuild finishes.
(Neil Lalonde) #6
It has “ads” in the url, so that’s enough for an ad blocker to block it. :laughing:
(Jeff Vienneau) #7
How crude!
That fixed it, thanks!
(Neil Lalonde) closed #8
#9
Thanks for adding this! I’m now trying to change from custom CSS to using this.
I’m getting a network error when opening the House Ads tab from the plugins page though.
Discourse Version: 2.2.5 (current stable version)
Force HTTPS: On
Using Cloudflare with their flexible SSL (attempted in development mode also, no firewall enabled). Tried with both www subdomain and non-www.
If I manually go to the json file specified in the error message below, it loads fine. Just get this error from opening the House Ads tab on the plugins page:
House Ads in the official Ad Plugin
(David Taylor) #10
Try turning off your ad-blocker, then reload the page
#12
That fixed it! :heart: Thanks @david
