Ad Plugin ads showing too often
#1
I just wanted to ask a quick question. I have upgraded to Discourse v1.6.10 and I am using the ad plugin. But every time I enable it and fill out the “nth post” section I get some awkward behavior in the topics.
For instance, if I set it to every 8th post, ads show up after every other post. Same thing happens if I set nth post to 5 or 15. Any ideas on what may be the cause?
Advertising Plugin for Discourse - Serve Ads on your Discourse Forum (Official Endorsed)
(Neil Lalonde) #2
Which type of ads? AdSense, DFP or Amazon?
#3
It is google Adsense.
(Neil Lalonde) #4
I’m not seeing anything weird. I set publisher code (a number), ‘adsense post bottom code’ (a number), and ‘adsense nth post code’ to 5. I see ads every 5th post. Do you have anything else set? Any other plugins installed?
(Neil Lalonde) #5
@will_io You definitely have both DFP ads and AdSense. Every 2nd post I see dfp-ad-units and every 15th I see google-adsense-content. Disable DFP and it will work.
#6
Wow that was obvious. Thank you for your help nonetheless!
(Neil Lalonde) #7
