Add Category Column
FYI I don’t know if this is causing confusion, but the Category Column feature was removed from the TLP plugin as per this post:
Just make sure you weren’t relying on TLP for this feature and that this Theme Component was fully activated.
It would appear that the latest update to Add Category Column does not work with discourse 3.2.8. With help, guidance and code from @tshenry I have built what is effectively the previous version and the column is back.
Jim
