Add custom icons to Hamburger menu
(Eloi Smith) #1
Hi there.
Is it possible to add custom icons to the hamburguer menu? I would like to use font awesome not only for admin, flags but also for latest, new,etc.
40
is that possible? if so, where it might be edited?
Thanks!
(cpradio) #2
Yes, you just need to learn CSS to target the correct link (for the New link).
ie:
.menu-links .new-topics-link:before {
  content: "\f2b9  ";
  font-family: FontAwesome;
You can open the hamburger menu and right-click on a link, choose Inspect to figure out how to target the link.
(Eloi Smith) #3
ok thanks! Got it! :slight_smile:
(Eloi Smith) #4
Sorry again, i’ve tried adding your code as example in the CSS of the defautl main theme, but unfortunately the icon is not showing.
I just need to add this CSS and then keep on targeting each like unread-topic.link, top-topic links…?
excuse my ignorance!
(cpradio) #5
My bad, I had a typo.
.new-topics.link should be .new-topics-link
(Eloi Smith) #6
Great, that works now :slight_smile: thanks thanks!!
