Add instructions for a multisite setup?
(Freekvh) #1
Hi, these instructions are very clear: discourse/INSTALL-cloud.md at master · discourse/discourse · GitHub
However, I would like to dedicate my droplet to multiple sites (it already runs some drupal and some pure html sites), could you perhaps add instructions for using the docker in this way? It suggests to bind the docker to another port but the install script does not suggest how.
Or otherwise, instructions for a non-docker install (would this be too complex?) so that I can use Nginx to do multiple sites and use letsencrypt for https.
Highest regards,
Freek
(Jeff Atwood) #2
There are already #howto topics on the questions you are asking; have a look.
