Add links to menu bar
(Phillip Kuoch) #1
Hi,
I was wondering if it was possible to add links to the Discourse menu bar? This way, it would be useful to add a link back to our blog!
Thanks!
(Michael Downey) #2
We use a common piece of JavaScript across all our sites to add a header with links to our community’s various sites. This can be added in your admin’s customization section.
(John Arce) #3
@downey Can you show me the example code for adding links to menu bar?
(Michael Downey) #4
Sure, the code for the menu bar we’re using is at: GitHub - openmrs/openmrs-contrib-id-globalnavbar: Global navigation bar across OpenMRS Community.
#5
I’m not clear what you are referring to here. If this approach is still relevant can you please give some more detail where this JavaScript can be added.
(Joshua Rosenfeld) #6
The approach is still relevant. You can easily add HTML or JS to your site from the Admin interface. Navigate to your_site_domain/admin/customize/css_html. You can then add a new customization, name it, and add all the CSS, HTML, and JS you want.
