Add plugin via bitnami deployment
unsupported-install
(Collin Moore) #1
So I am trying to add some plugins via a bitnami deployment but there isn’t a containers/app.yml file.
Anyone have any knowledge of how they set it up and how to add plugins?
Much appreciated.
(Jeff Atwood) #2
You have probably heard my lecture on this already, but I am obligated by law to now inform you that we only support the official Docker based install.
(Collin Moore) #3
darn. egg on face. I’ll investigate further and look at a docker deploy. Using azure, so it was easy to use bitnami.
(Manthan Mallikarjun) #4
Which plugin are you trying to install? I can try and help.
(Collin Moore) #5
@nahtnam I ended just deploying on azure using a docker profile. it was hidden. thanks though.
(Carl Pham) #6
@nahtnam: I want install plugin : GitHub - tcreativo/plugin_discourse_dynamic_sidebar: A Discourse plugin to add a dynamic sidebar on the right.
Can you help me?
(Manthan Mallikarjun) #7
Are you using docker?
(Scott Trager) #8
Pretty sure that plugin is broken at the moment.
(Carl Pham) #9
I used bitnami (Discourse Cloud Hosting, Discourse Installer, Docker Container and VM)
