Add rel nofollow tags for posts created by Admin
#1
Hi All
I see in my Admin section under SPAM category the “no follow” tag is already checked. However when I do view source I do not see nofollow tags in the forum for posts created by Admin.
It appears that the nofollow tags will be not be applied to posts created by Admin, is this correct?
Is there a way to also apply nofollow tags to posts created by Admin?
Thanks
Below is the description for the rel nofollow check box selection in Admin:
"add rel nofollow to user content
_ Add rel nofollow to 'all submitted user content, except for internal links (including parent domains). If you change this, you must rebake all posts with: “rake posts:rebake”_
