Add top_menu item to specific category
(Andrew Ballerstein) #1
Is there a way to link to a specific category in the top menu? By default there’s a link to /categories. How can I add a link to /category/categoryname?
(Jacob) #2
Pretty much that.
In the top_menu settings latest|new|unread|favorited|categories|category/CategoryName
Adding items to navigation bar?
(Andrew Ballerstein) #3
Thanks for the reply.
Yea, that would make a ton of sense. :]
When I do that, the href is set to ‘category/null’. It gets the title of the li right though. Any ideas would be appreciated.
http://thegoodexchange.discoursehosting.net/ - ‘Need’ and ‘Offer’ in top nav.
Thanks
(Jacob) #4
I didn’t check out you site yet but make sure it’s in the proper case. If I remember correctly, it’s case sensitive.
(Andrew Ballerstein) #5
It was totally the case. I would have never thought of that.
Thanks so much. I really appreciate it.
(Christian Simplicity) #6
Awesome. Thank you!
Can I add an external link in that menu?
How about a link to a specific topic?
