Hi there - I’m trying to add plugins to my discourse forum via the console in digitalocean but having some difficulties…
I’m following the instructions of accessing:
cd /var/discourse
nano containers/app.yml
But when I enter the command, I get a bash response saying ‘no such file or directory’
Any help would be appreciated! Thanks in advance.
Duncan
Was it a digitalocean one click install?
Hey Bhanu thanks for the follow up - I had to install discourse manually in digitalocean, not the one click install.
What is the output of
ls /var/discourse/containers
when I input ls /var/discourse/containers
the output is :
ls: connot access ls /var/discourse/containers
: no such file or directory
Is this the correct server? Why does it seem like your installation isn’t standard.
Does /var/discourse exist?
ls /var/discourse
I believe it’s the correct server?
ls /var/discourse doesn’t exist either though - so it seems like something isn’t set up properly?
I’m trying to access my root@(myip) but a 'permission denied (publickey) response now
That error means Your server uses key pair authentication instead of password. Do You remember setting up an ssh key?
Yes yes I have set up an ssh key. I suppose I will need that key to access my server and make any changes?
Yes! you’ll need to configure your ssh client to present your private key to the served for authentication.
When I open my console in digital ocean I’m already in as root@discourse-beta-ubuntu-s-2vcpu-4gb-nyc3-1-app:~#
I think I figured out the mistake - the SSH key is pointing to the wrong IP address ( an old forum I had set up).
I updated the SSH key, but can’t seem to SSH into my new droplet. Thoughts?
