Adding Assets via plugin similar to Bower?
(Emanuelet) #1
Hi Guys,
I’m developing a customised Discourse and I ran into an issue.
I will like to add Polymer on my assets, but I will like to do it in a maintainable way (something similar of having a bower.json) through a plugin.
Any suggestion on the right way to do it?
Bower?
NPM Ember-polymer?
Gem ? (polymer-elements-rails?)
Cheers
(Robin Ward) #2
Right now we’re not using anything like bower or npm although at some point I’d like to get us set up.
It would be cool if someone could create a bower/npm plugin for discourse so you could have a json file and have it install the dependencies you need.
Until then, you will be forced to create a plugin that just imports a vendored file.
(Emanuelet) #3
Ok, I’ll add them manually.
My only other question is: can I do something like this to import the various components?
register_asset 'bower_components/paper-button/paper-button.html'
The way you do in regular html is
<link rel="import" href="../bower_components/paper-button/paper-button.html">
(Aedensixty) #4
(post withdrawn by author, will be automatically deleted in 24 hours unless flagged)
(Aedensixty) #5
I am trying to do the same thing. Is there anymore information on this?
We are trying to get polymer elements working in a plugin. Is there some way to use html imports with the register_asset function?
