Hello,
I am just try to add icons to the center of d-header.
I use for desktop this theme component but this one is float to the right and connect to the .panel .navigation class
I use the Discourse Tab Bar component as well on mobile. So i want to display the Discourse Tab Bar icons on desktop too in the center of d-header. Is that possible somehow?
Looks something like this
Other important things:
Only show on logged is users. (i can make it use the .anon class i think)
When the topic title change on header then these icons should be hidden.
Thank you!
