Adding Custom Code to Header
(Hexa) #1
How can I reference resources for code for a custom header on Discouse? I would like to add a menu above the existing top bar. Can I upload CSS, JS, HTML somehow? Also, do I upload the HTML in the head or /header section?
(Erlend Sogge Heggen) #2
There’s plenty of guides on this:
https://meta.discourse.org/search?q=%23howto%20header
(Hexa) #3
Thank you! I will read the article and let you know if I have any questions. :slight_smile:
(Hexa) #4
Where do I upload the css, stylesheets, etc?
(cpradio) #5
Admin > Customize > Themes
(Hexa) #6
Do I go into an existing theme?
(cpradio) #7
You can, or you can create a new one and treat it as a component, then add that component to an existing theme.
(Hexa) #8
How do I do that? Can you walk me through it or is there an article on Meta?
(cpradio) #9
I’m not sure what you are struggling with.
  1. Visit Admin > Customize > Themes
  2. Click New
  3. Click Pencil Icon to give it a name
  4. Click Edit CSS/HTML (enter what you need)
  5. Click on the active theme (the one with the asterisk)
  6. There is likely a drop down of components you can add, find your newly added one and click the Add button
  • If there isn’t, check the box permiting the theme to have child themes.
(Hexa) #10
So, I just add the content in the new theme and add it as a child theme? Where do I add the CSS and what section does JS go?
(cpradio) #11
Following that search link from @erlend_sh should help you out with that part :wink:
