Adding items to navigation bar?
#1
How to add more “Buttons/Categories” to navigation bar?
Private categories show up in nav menu when user does not have permissions
(Christopher Heald) #2
Admin > Settings > Basic Setup > top menu
You can add, remove and reorder items.
#3
@OnceWas i know about that, but how can i add these;
(Christopher Heald) #4
Use this syntax: ‘category/CategoryName’
(Christopher Heald) #5
Interestingly, category/ has been replaced with c/ in the URL, but ‘c/CategoryName’ doesn’t work as a top menu item.
(Jeff Atwood) #6
Hmm we should fix the above @sam
#7
@OnceWas Thanks ‘category/CategoryName’ Works fine :smile:
(Sam Saffron) #8
Those buttons are added with
admin -> customize -> css/html -> </body>
<script>
  Discourse.ExternalNavItem = Discourse.NavItem.extend({
    href : function() {
      return this.get('href');
    }.property('href')
  I18n.translations.en.js.filters.bugs = { title: "Bugs", help: "Open Bugs" };
  I18n.translations.en.js.filters.features = { title: "Features", help: "Open Feature Requests" }
  Discourse.NavItem.reopenClass({
    buildList : function(category, args) {
      var list = this._super(category, args);
      if(!category) {
        list.push(Discourse.ExternalNavItem.create({href: '/category/bug?order=op_likes&status=open', name: 'bugs'}));
        list.push(Discourse.ExternalNavItem.create({href: '/category/feature?order=op_likes&status=open', name: 'features'}));
      return list;
 </script>
We just need to simplify navitem control, I am thinking this belongs in customize in a separate section cause there is a fair amount of richness you want there.
Where or how does the function defined?
