# Adding "latest topics" header in the main interface
**URL:** https://meta.discourse.org/t/adding-latest-topics-header-in-the-main-interface/402188
**Category:** Support
**Created:** [May 5, 2026, 7:10am UTC](https://meta.discourse.org/t/adding-latest-topics-header-in-the-main-interface/402188 "2026-05-05T07:10:08Z")
**Posts on this page:** 4
**Page:** 1
<div class="post-metadata">
### Author: ![Evrim\_Dirik](https://sea3.discourse-cdn.com/meta/user_avatar/meta.discourse.org/evrim_dirik/32/552007_2.png) [@Evrim\_Dirik](https://meta.discourse.org/u/Evrim_Dirik)
#### Post date: [May 5, 2026, 7:10am UTC](https://meta.discourse.org/t/adding-latest-topics-header-in-the-main-interface/402188/1 "2026-05-05T07:10:08Z")
</div>
Hi everyone, sorry for a novice question but I did my best to search the forum for the answer.
How can I add the header “latest topics” as seen below in my theme? I am using the foundation theme.
 ![Screenshot 2026-05-05 at 09.08.17](https://global.discourse-cdn.com/meta/original/4X/8/a/e/8aede8bf1d9c0b37d86e77fc9d32f952c768143f.jpeg)
### Author: ![NateDhaliwal](https://sea3.discourse-cdn.com/meta/user_avatar/meta.discourse.org/natedhaliwal/32/313494_2.png) [@NateDhaliwal](https://meta.discourse.org/u/NateDhaliwal)
#### Post date: [May 5, 2026, 7:17am UTC](https://meta.discourse.org/t/adding-latest-topics-header-in-the-main-interface/402188/2 "2026-05-05T07:17:27Z")
</div>
This theme on Meta is custom. It would be better to show a screenshot of the desired location on your forum. Thanks.
#### Post date: [May 5, 2026, 8:01am UTC](https://meta.discourse.org/t/adding-latest-topics-header-in-the-main-interface/402188/3 "2026-05-05T08:01:40Z")
</div>
Sure, so I want to add it above the text area including “kategoriler, etiketler, en son etc.” so somewhere like inside the Red Box, which I marked.
 ![Screenshot 2026-05-05 at 09.59.49](https://global.discourse-cdn.com/meta/original/4X/3/5/a/35a78209ccce3b6cb1eac9a2a26e5e6d19e28a61.png)
### Author: ![chapoi](https://sea3.discourse-cdn.com/meta/user_avatar/meta.discourse.org/chapoi/32/537252_2.png) [@chapoi](https://meta.discourse.org/u/chapoi)
#### Post date: [May 5, 2026, 11:06am UTC](https://meta.discourse.org/t/adding-latest-topics-header-in-the-main-interface/402188/4 "2026-05-05T11:06:43Z")
</div>
You can insert it with the `discovery-navigation-bar-above` outlet.
How to use outlets info can be found here: [Using Plugin Outlet Connectors from a Theme or Plugin](https://meta.discourse.org/t/using-plugin-outlet-connectors-from-a-theme-or-plugin/32727)
