Adding location at sign up
(Mark Ridsdill Smith) #1
I want to collect users location at sign up.
Is there a way to add the EXISTING Location field (in the user profile) to the sign up form?
Or to I need to remove the existing Location field (if so, how?) and add custom user fields for the location?
Thanks in advance for any help.
#2
This is not a direct response to your question, but also consider the Locations Plugin which has a lot more functionality than the out-of-the-box solution and allows you to display user locations on a single map…
(Mark Ridsdill Smith) #3
Thanks @merefield. I love the look of your locations plugin - I’ve wanted a map which shows user locations for ages…
At the moment, I’m new to Discourse, not very technically able, and focussing on trying to master the basics of the platform. When I feel ready to move on, this will be one of the first things on my list to do.
How much technical knowledge do I need to install and work this plugin?
#4
It’s not my plugin, I’m just referring. It’s @angus & @Sudaraka’s :slight_smile:
You need to edit app.yml and rebuild the app, not super technical.
The guide to do that is here:
