Adding Mailchimp Subscriber popup
(Tor) #1
Hi,
I’m trying to add the mailchimp Subscriber popup in the forum and added the code in the header. But the popup is not showing. I think it has something to do with the java script?
(Tor) #2
This is the code I have in the header
(Tor) #3
this is the error log:
Error: Could not find module [object Object]
at a (http://www.kunstveggen.no/assets/vendor-57997c9be5e2eb295af84ffc057f62ed.js:1:10861)
at requireModule (http://www.kunstveggen.no/assets/vendor-57997c9be5e2eb295af84ffc057f62ed.js:1:11740)
at http://s3.amazonaws.com/downloads.mailchimp.com/js/signup-forms/popup/embed.js:2004:4
(Tor) #4
Please someone help.
pulling my hair
(Régis Hanol) #5
What is that Mailchimp Subscriber popup? Can you point us at some documentations?
(Tor) #6
(Régis Hanol) #7
I’m afraid this doesn’t help me since I have no experience with that part of Mailchimp. Maybe you should ask one of the Mailchimp Expert?
(Tor) #8
Its a paid service I think.
The popup does not show and I think its because of the java script.
(Tor) #9
According to this wordpress mailchimp bug it has something to do with the jquery.js.
Could it be the same error/bug in discourse?
(Neil Lalonde) #10
Yes it’s the same issue. Discourse loads jQuery for itself, and mailchimp’s embed.js is trying to load another version of jQuery. If they offer a way to load it without jQuery, or if it can assume jQuery is already loaded, it might work.
(Mittineague) #11
Even if it would work I fear it would require a massive amount of code rewriting. eg.
var discourse_jquery = jQuery.noConflict();
many changes eg.
        if (options.settings) {
          Discourse.SiteSettings = jQuery.extend(true, Discourse.SiteSettings, options.settings);
to
          Discourse.SiteSettings = discourse_jquery.extend(true, Discourse.SiteSettings, options.settings);
(Tor) #12
But is it possible to use the same jquery as discource like in the link?
(Neil Lalonde) #13
You’ll have to get help from Mailchimp on this. https://experts.mailchimp.com/ Their popup code isn’t very portable, and they should fix that.
(Tor) #14
Thanks for the help @neil
(smartwatchme) #15
You could also try some tools like SumoMe?
#16
Has anyone had success integrating SumoMe with discourse? I’d be very interested to see how this is done.
(smartwatchme) #17
Yes it’s very easy, you just add a small line of javascript code to your header!
(Tor) #18
Just added the SumoMe. Very impressed! Works like a charm. Thanks @smartwatchme
