Admin/Upgrade Blank
#1
New Discourse user here
Had everything installed fine, then tried to do an update on the Docker Manager and now when i go to site/admin/upgrade I’m only presented with blank screen.
Any tips would be greatly appreciated
(cpradio) #2
I would remote into the server and run
cd /var/discourse
./launcher rebuild app
Once that completes, then try accessing the admin pages again.
(Andrew Waugh) #3
You didn’t by any chance comment out or delete the docker plugin in your app.yml did you? This will cause /admin/docker to disappear.
You need the line:
#4
Rebuild updated my site but docker manager hangs half way though upgrade.
last comments
***  Bundling assets. This might take a while ***
$ bundle exec rake assets:precompile
Purging temp files
Start compiling CSS: 2017-03-01 00:37:23 UTC
Compiling css for default
target: desktop desktop_6f1ed7b53230e0c46868b8865bd4ca09c319eea9.css
target: mobile mobile_6f1ed7b53230e0c46868b8865bd4ca09c319eea9.css
(cpradio) #5
How much memory and swap do you have? If you have 2 GB or less of RAM, you need a 2 GB swap file.
#6
2G ran, and plenty of SSD space. which swap file should i be checking (such a noob)
(cpradio) #7
Run free -m, that will tell you if you have swap setup and how much you have setup.
