Adsense questions
#1
Hi All , some Adsense related questions:
  1. I see that in Discourse ADMIN settings there is already an area where we can enter our Adsense publisher ID, so why are some people getting an Adsense plugin? I would assume by entering our publisher ID in the admin settings in Discourse, that should be sufficient, no ?
  2. Is it true that Adsense will only work for top domain URLs? So if my forum is forum.mysite.com, then there is no way for Adsense to work?
Many thanks in advance.
#2
No - it works fine on my subdomain forum.
#3
Thanks. Did you use a Adsense plugin or did you simply enter your publisher code in Admin settings? I read older posts and people were talking about using an Adsense plugin in their Discourse forum, not sure what the plugin actually does.
#4
No, but I do use the discourse-adplugin to serve DFP ads.
#5
Thanks, what does DFP stand for?
(Jeff Atwood) #6
You can probably google that and find out.
