Advanced Setup Only: Allowing SSL / HTTPS for your Discourse Docker setup
I encountered the same problem in the same scenario. Seems wrong that some assets use the wrong scheme, even if they are replaceable
If it is ERR_TIMEOUT, check out the safety group, add https-443 rule on server, e.g. AWS EC2. It works for my situation.
But then you say
Whats the correct folder now? /shared/sll/ or /shared/standalone/ssl ?
Inside he container, there is no standalone.
To be clear for other people:
/var/discourse/shared/standalone/ssl/ssl.key is meant to be on the host itself.
/shared/ssl/ssl.key is meant inside the docker container. So if you run ./launcher enter app (app is your .yml-File within /container/) you will see /shared/ssl/ssl.key.
Thanks for your answer.
