Advanced Setup Only: Allowing SSL / HTTPS for your Discourse Docker setup
What does your app.yml look like? Do you have the letsencrypt template installed for some reason? That could be overwriting your certs, maybe.
What do the invalid ones look like?
You are absolutely right. Unfortunately, our instance is not accessible from the internet (people need to connect through VPN to access it)…
Due to GDPR restrictions and various local laws about confidential information, it is usually easier to prevent access from Internet…
I left the default in the app.yml which uses Let’s Encrypt. This was certainly an error from my side. The key is an empty file. I believe it comes from the fact that Let’s Encrypt fails to connect back to the machine.
Since you’re not using Let’s Encrypt, you should not use let’s encrypt, so just delete or comment out that template from your app.yml.
Also, you can edit your posts rather than replying to yourself a bunch of times.
Thanks for the reply. You are right the Let’s Encrypt template is activated.
That was it. Thanks!
Sorry about the replies to myself. I just wanted to quote the portion of you answer so you would know which part of your answer I was referring to.
Glad you got it. FYI (we’re all here to learn) you can repeatedly select text and click quote–even if you navigate to other topics!
Thank you. It works great!
Is there a command option to install a new TLS certificate without running “./launcher rebuild app”?
I ask because our servers are running on v2.4.0beta5 with a custom plugin that breaks on anything after v2.5. When I run “./launcher rebuild app,” my system magically gets upgraded to v2.6.0.beta1 :grimacing:
I understand the right way to go about this would be to hire a developer to re-write the plugin for v2.6.0beta1, but the TLS cert expires in a month, and I feel concerned that I may not have enough time for them to complete the work.
Sure is, look at my posts from January in this topic.
If you’re using a standard install, it’ll renew on a couple of days.
Thank you for getting back to me so quickly. I used ./launcher restart app - and it picked up the renewed Comodo/Sectigo TLS cert without any problems! LIFESAVER. I will sleep better tonight. :sleeping:
