Advice on collecting topics created per category for basic trust level users
Are we able to track the number of actions users take in a particular Trust Level?
For example, am I able to collect data on how many topics a Basic user makes?
If so, how far does this go? Can I then know which categories these topics are being made in?
We’re starting a new program in our community and need to track this data to help measure success.
Thanks!
Hey Quentin,
If you install the Data Explorer plugin you can query the database and get pretty much anything (depending on your SQL skills).
Thanks for the fast response! This is definitely something to consider. :slightly_smiling_face:
If you need help to write the queries, post your criteria here and I’m sure someone will step up.
