"After Header" Content Showing on Every Page
Hello, after adding a welcome paragraph into the “After Header” section under Customize, I noticed this content displays on every single category and topic page. Even after removing the CSS file and going back to what came with the initial set up before we started designing, it still shows up on every page so I don’t think it has anything to do with my existing CSS or HTML. It seems like it’s the default setting. Is there a way to hide this so it only shows up on the main page? Would be nice if it’s an existing setting somewhere (like unpinning the main header), but I’m guessing it’s a little more complicated than that and will require some CSS work? Does anyone have a tutorial on how I might get this to hide everywhere else but the main page?
I think what you’re looking for is a globally pinned topic :wink:
Where exactly is that located…I can’t seem to find it.
I’m not trying to pin an actual topic…it’s the banner header under Customize.
In a topic, click the wrench :wrench: icon and then Pin Topic.
What you described is exactly what pinning a topic does.
Thanks for the feedback, unfortunately creating is as a topic doesn’t seem to work with the HTML/CSS currently used in the header.
